question
Old Oct 4, 2002 | 08:08 PM
ImportHatch's Avatar
Default question
Can I put y7 clutch, flywheel and pressure plate in a cable si tranny? Seems like it would be the same for y7, just need someone elses opinion.....heres the quote.
Clutch, pressure plate and flywheel…The 90+ setups have a wider surface area then the 88-89 therefore offering more contact area and thus more effective power transfer. The Z6 with stock clutch, pressure plate and flywheel will bolt directly onto 89+ year transmissions. It will not bolt directly onto an 88 transmission unless the proper 88 clutch, pressure plate and flywheel are used (due to the 88s having a different spline count on the input shaft). 92+ transmissions can’t be used due to them being hydraulically activated, and the mount positions on the 92+ transmission being different then the ones on the 88-91 transmissions.
thedudefromjerz
Aug 1, 2008 09:54 PM
PLAN:B
Jun 28, 2005 09:21 PM
Gant
Aug 4, 2004 06:43 PM
ImportHatch
10
Oct 6, 2002 01:21 AM
