LS turbo instal... ez or hard
Old Oct 4, 2002 | 08:00 PM
ILLA_00LS's Avatar
Default LS turbo instal... ez or hard
this weeek i'm doing it.. boost baby..
need to know if this will be hard to do!
the shop i got it all from said he will do it all(turbo,cluch,flywheel,injectors,reinforced motor mounts)
for 600$ what should i do?!?! i'm stuck.. get the money or do it my self..
nobody in the team as done a cluch yet, but the rest shouldn't be hard.. the only part bout the turbo i'm stressing is the oil pan tap.
please help
thanx
ILLA
00 LS
Apexi N1/Wrold sport coil overs
AEM CAI
14" BF Drag rad.
15.4
(stripped everything, and 1/4 tank )
Old Oct 5, 2002 | 07:11 AM
FORCED FED TEG's Avatar
New User
Default Re: LS turbo instal... ez or hard (ILLA_00LS)
You should ask in the FI form. I installed mine in a weekend but I did a lot of research before hand. As for tapping the oil pan I used a bulkhead fitting no need for welding. http://www.overboost.com/story.asp?id=57
Old Oct 6, 2002 | 05:11 PM
boostinb18's Avatar
Default Re: LS turbo instal... ez or hard (FORCED FED TEG)
i takes me about a hour and a half.....not including getting the oil pan welded....but since youve never done stuff like this it will probably take you a while! and clutches are pretty easy.
Old Oct 7, 2002 | 06:28 PM
Danger's Avatar
its not really that hard . is it a brand new kit or did you buy a used kit ?
Old Oct 7, 2002 | 07:14 PM
ILLA_00LS's Avatar
Default thanx much..
i talked to most of my friends.. and we all desided it would save us from any probs so i had the shop do it.. so.. thanx much yall
later.. i'll let u know how it comes out!
Old Oct 8, 2002 | 11:10 AM
Elite Hatch's Avatar
Default Re: LS turbo instal... ez or hard (boostinb18)
You can install a clutch, complete turbo kit, and motor mounts in an hour and a half????
[Modified by Elite Hatch, 3:11 PM 10/8/2002]
b20vteclsintegra
Northwest (Sales)
Feb 28, 2011 01:45 PM
JDMTurboEG6
Dec 19, 2007 11:23 AM
RCautoworks
Aug 25, 2006 12:54 AM
JDMTurboEG6
Apr 6, 2005 01:16 PM
