hf to si...
Old Oct 4, 2002 | 07:49 PM
91HATCH's Avatar
Default hf to si...
need to know if theres any wiring difference?
Old Oct 4, 2002 | 08:16 PM
xtrafastcivic's Avatar
Default Re: hf to si... (91HATCH)
no.....
Old Oct 4, 2002 | 08:19 PM
MrTodd's Avatar
Default Re: hf to si... (XtraFastCRX)
What are you trying to do? Swap a Si motor into a HF chassis?
If so, the wiring is pretty much exactly the same - just use your old HF harness.
I think some of the harness plugs have slightly different pin locations (between HF & Si). So basically if you use the Si harness, it's prolly not gonna plug into the rest of the HF harness that's in the car....
At least, that's just what I've heard. I've never done any work on HF cars, I only know my '90 Si!
Good Luck
Old Oct 4, 2002 | 11:28 PM
incubus's Avatar
Default Re: hf to si... (MrTodd)
Mr todd is right to my knowledge. both engines use mpfi, unless u r talking about 1st gen then the hf's r carbed and are totally diff harnesses than the si. diff config of wires like todd said.
Old Oct 5, 2002 | 11:45 AM
skud_dusty's Avatar
Default Re: hf to si... (incubus)
so an with an 88-91 hf, an si engine would drop right in, no wiring changes?
theres a local hf in really good condition...if i got the si engine tranny (better ratios?) and ecu, it would drop right in no prob...correct me if i'm wrong
Old Oct 5, 2002 | 02:39 PM
Aphrodavid's Avatar
Default Re: hf to si... (skud_dusty)
dropping an 88-91 SI motor into an 88-91 HF is completely R+R, even the wiring harness.
Old Oct 6, 2002 | 07:42 PM
91HATCH's Avatar
Default Re: hf to si... (Fast 1point5)
hf has more sensors than the si...how is wiring the same? i believe there is some kind of changes
Old Oct 7, 2002 | 02:07 AM
vtec crx's Avatar
its the same harness,did it about 20 times,just dont run the egr
Old Oct 7, 2002 | 02:12 AM
Stupid Ass's Avatar
Default Re: hf to si... (vtec crx)
Nope, the HF and SI is the same... you don't need to hook up the EGR thats all.
[Modified by SOHC NoTEC, 6:12 AM 10/7/2002]
Old Oct 7, 2002 | 01:10 PM
Timmah!!'s Avatar
Default Re: hf to si... (SOHC NoTEC)
There is a sensor on the bottom right of the Si intake manifold the my HF harness has no plug for and the old HF manifold did not have this sonsor... Could there be differences in years??
Old Oct 7, 2002 | 01:24 PM
91HATCH's Avatar
i got some info from a friendly guy from the hybrid site....
he said that if you plug and play...it will work but will throw codes...
he told me there is six wires at the ecu that hf has that si doesnt need
these are the wires that should be eliminated
A6 - EGR seloniod control
B2 - shift indicator
B7 - clutch switch
B9 - reverse sensor
B11 - heater sensor
C8 - EGR signal
if im wrong please correct me
Old Oct 7, 2002 | 05:28 PM
big pete's Avatar
there are a couple minor differences....look up...not sure if all are right but there are minor differences
Old Oct 8, 2002 | 12:41 AM
irev210's Avatar
Default Re: hf to si... (big pete)
what about knucles, arent they different?
Old Oct 8, 2002 | 12:24 PM
ZC'n'it's Avatar
I just did a hf to si swap this weekend the only problem I had was left over vacum lines.I had no trouble with wiring.
Old Oct 8, 2002 | 03:30 PM
technine's Avatar
Agree with this. Did that, done that.
Old Oct 12, 2002 | 05:33 PM
91HATCH's Avatar
Default Re: hf to si... (ZC'n'it)
wat did you do for the wiring?
Old Oct 12, 2002 | 05:51 PM
ZC'n'it's Avatar
All of the wiring matced up
Old Oct 13, 2002 | 10:05 PM
91HATCH's Avatar
any check engine light? can you give me a pic of how you did the vacuum lines?
Old Oct 14, 2002 | 03:09 PM
ZC'n'it's Avatar
I don't have any pics to send you .If I remember you should have one or two vac lines.They were the ones that went to the egr which was on the intake.
[Modified by ZC'n'it, 12:13 AM 10/15/2002]
Old Oct 14, 2002 | 04:15 PM
MrTodd's Avatar
Default Re: hf to si... (sirhatchback)
Yup. In order to use the Si tranny w/Si axles, you must install Si knuckles as well.
Once again, I don't have experience to back this up. But I'm pretty sure about this.
Old Oct 15, 2002 | 12:46 PM
Timmah!!'s Avatar
I need to know if you sure about that??
I am Finaly going to get rid of my HF tranny and will be using an Si tranny and axles so I would like to get a "for sure" answer on that... And if so will the ones off of a 91 civic DX work?? Along with the front breaks.. (I think they are bigger than the HF)
Old Oct 15, 2002 | 12:47 PM
EP3_05's Avatar
Default Re: hf to si... (azroth)
Si/DX hubs are definitely different than the HF/STD hubs.
Old Oct 15, 2002 | 04:39 PM
ZC'n'it's Avatar
Default Re: hf to si... (91civic)
I agree that the hubs are different.
Old Oct 15, 2002 | 05:03 PM
allmotorEG-SI's Avatar
The si tranny should work no problem in a hf chassis even with the old hubs. The trannys are all the same except for some gear ratios. But swap to Si's anyhow. they're bigger to start with an have more aftermarket parts avaible and you wouldn't even have to worry about whether it would work or not.
fullraceacura
May 24, 2005 09:49 AM
aaronbb22
Mar 18, 2004 06:21 AM
I Gotta Question
Feb 11, 2003 10:18 AM
Tbone
Jun 18, 2002 01:34 PM
CimorelliCRX
Apr 18, 2002 02:14 AM
