Fuel Lines ?
I'm getting ready to instale my inline fuel pump and filter. What size lines do u recomend 6 or 8? It's the MSD pump and paxtone filter on an all motor.
Second just so I do it right. It goes fuel cell, line, filter, line, pump ,line to fuel rail. Any pics of your guys setups would help.
Thanks
Ryan
Thanks
Ryan
That was going to be my next question what would it take for me to run methanol. I have a jg reline head witha a basic ls vtec set up. I have a one gallon fuel cell would that be enough for a burnout stage and race?
i am not completely knowledgable about the use of methanol however as i understand it, you need somewhere in the neighborhood of twice the fuel. 1 gallon tank might not be quite enough. perhaps 1 1/2 or 2 gallons? maybe someone else on here knows a little. and be prepared to blow motors. using meth for the first time is like jumping into the ocean and kinda knowing a little bit about swimming. its a pretty large learning curve.
thanks, I had a feeling it was a little more advanced and an average joe should stay away. What octane and gas do u recomend as well as fuel managment?
Id run the filter before your pump unless you dont care about the life of your pump...thats the way you have it. If your gonna run meth, you cant have any aluminum in line...thats fuel cell, lines, pump (yours most likely wont work) and rail. 1 gallon cell should be plenty on a all motor car for meth...Mike
It's not the I haven't figured everything out, I like to get opinons form these guys. They know way more than any person around here. So far I have nothing but postive advice that has helped me out a lot. I was thinking about running meth but I just want to get the thing running, two years to long. I still need a fly wheel, Diff, and throtle body and then it needs to be wired.
Fellas what racing fuel do you reccomend and octane?
Thanks
Red
Thanks
Red
hey red if you didnt realize this is Ge-off...........what management are you going with??? and what kind of flywheel you lookin for??? i have a stock LS flywheel for sale.
I know it's you bro. I want to go with a Jun flywheel. I have 93 civic ex wire harness that i was think of useing with a chipped ECU. I havent' looked into the fuel managment that will so my knowlegde isn't to good yet. Mybe you or someone else has so ideas. Looking for something that is good and possible I can learn how to use and tune
ryan
ryan
personallly id just run the harness you have and the chipped ecu for a while untill you get used to your car at the track and then upgrade to hondata or sds or AEM EMS......or whatever you want to go with.....then tune from there!
vr6chris
Nov 5, 2005 05:30 AM
Flamenco-T
Sep 28, 2004 11:32 AM
