Car shakes when I stop!
Old Sep 22, 2011 | 10:02 AM
Mr.Honda00's Avatar
Icon2 Car shakes when I stop!
2000 Honda Accord, swap from F23a4 to f23a1... Remarkable difference! But anyway... Say I drive, when I stop, the car like jumps forward before coming to a complete stop... I need some advice on a solution and reason why its doing this...
Old Sep 22, 2011 | 11:10 AM
jdmrespect11's Avatar
Default Re: Car shakes when I stop!
Have you checked tour rotors for unusual wear?
Old Sep 22, 2011 | 12:13 PM
75aces's Avatar
Check your axles and also your brake pads too. Does the pedal feel soft?
Old Sep 22, 2011 | 02:52 PM
Steve Z's Avatar
Sounds like you have transmission problems. I saw you posted another thread about the trans taking a few second to engage from reverse to 1st or vise versa. Sounds like the torque converter is hanging up or electronic lockup not disengaging right off. After a while the car will stall as if you didn't push in the clutch on a manual shift. The time between the shifts engaging are indicitive of trans problems too.
Old Sep 23, 2011 | 11:29 PM
djbuck04's Avatar
its either your torque converter or transmission. i've had this problem in a american piece of ish trust me
Old Sep 28, 2011 | 08:22 PM
justin123560's Avatar
x2
Old Sep 29, 2011 | 09:40 AM
Mr.Honda00's Avatar
I did a little research and most problems I have are symptoms of A/T Solenoids... I guess I will try that first... Anyone know where I can get the solenoids from?
jmk64
Jan 18, 2021 04:09 AM
MEngineer
Mar 14, 2017 01:38 PM
cpl rampage
Acura TL, RL & ZDX
Jan 11, 2012 06:27 PM
Losone
Sep 15, 2011 12:33 PM
knucklehead11
May 28, 2006 11:34 PM
