Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Having misfiring problems for my 05' Acura TL...
Old Sep 21, 2011 | 06:14 PM
Pete58drxl's Avatar
Icon6 Having misfiring problems for my 05' Acura TL...
So the misfiring problem is due to clogged/ faulty fuel injectors so I'm getting all 6 fuel injectors changed on my Acura TL. My buddy is doing it for me. He recommends changing the upper manifold gasket as well. There's a lower which he is not changing. Should I replace both the Upper and Lower Manifold gaskets with the install of the 6 new fuel injectors?
Old Sep 24, 2011 | 08:39 PM
slomofo's Avatar
GDD Member
Default Re: Having misfiring problems for my 05' Acura TL...
Lower manifold isn't coming off which is why he's not changing the gasket. The upper gasket is made out of metal and most people just reuse it, so be thankful he's even changing that for you.
Most common problems with misfires in those cars is the coils and not the injectors, so be sure you're changing the correct part before tearing it apart.
ic3man19
Sep 8, 2009 02:28 PM
Origin
Jul 4, 2008 01:00 PM
Laserjock
May 20, 2005 11:56 PM
Ryanwb
Mar 27, 2003 08:57 PM
Quick 200k Mile Motor
Feb 27, 2002 06:34 PM
