FS: Clean NJ title 95 Accord wagon LX w/H22 OBD1 swap
VIN: 1HGCE1724SA000755
10/16/2011 PRICE DROP $$$5900
10/6/2011 PRICE DROP $$$6100
9/29/2011 PRICE DROP $$$6300
$$$ 6500
respond to PM's only
Clean nj title 95 accord wagon Lx w/85k on body w/H22 obd1 swap from
95 prelude w/reciepts for everything.
Motor swap was off usdm 95 prelude si w/h22 eng & trans
Rebuilt the head and swapped all gaskets. .
spared no expense! Because this was my Daily Driver
NJ INSPECTION till 10/2012
Car was bought from 1st owner w/low mileage $1500
ACCORD LX W/FRONT X-DRILLED ROTORS AND Large FRONT CALIPERS (SAME AS
98 integra type-r)
LX were not equipped w/ABS ...so Rear Brakes are Drums which makes it
a lot Lighter (Drum shoes were replaced)
add $3500 for Usdm H22 swap.. Engine and Transmission was replaced
....Now you are at $5000
add at least $500 for rims and tires( even though it cost me more) = $5500
$375 for Bilstein shocks front & rear $225 for New H&R OE springs
(0.75 inch drop) you are at $6100
THan add the PPG Paint Job for $2000!(Emblems shaved & door jambs
painted too) you are at =$8100
Plus the exhaust system $400 ( 2.75 diameter Black coated Es tuning
muffler w/stainless catback)= $8500
304 STAINLESS Tubular Headers $150 ,Random technology Cat/converter
$150 , New 02sensor $100
Takata Green Air Filter/ intake $50, Exedy clutch w/new bearing $150
..... Total now = $9100
Brembo x-drilled front rotors & pads $200
Goodridge Stainless steel Brake Lines Front & Rear $100
Painted Mugen copy Front lip $100
Painted Xenon Rear Lip $200
Painted Wings West ROoF wing $200
NRG Bronze top front strutbar $100 = Im at $10,000!!!!
OBD1 P28 computer from 95 civic ( Prelude computer was giving out
check engine lights & P28 is easily tunable)- $150
Jdm STANLEY BLACK headlights from Inspire $150 = +300
New honda oem timing belt and tensioner $150
New honda oem water pump $75 and MUGEN thermostat (Operating
temperature: 68C (STD.: 76-80C) $75 = +$300
New aluminum radiator $200, Blue Obx radiator High temp hoses $100,
Fuel pressure regulator$150 and STR
high flow Fuel rail $150= + $600
Rebuilt head w/type-s cams, and New OEM honda Head gasket & gasket set
,new NGK iridium spark plugs more $$$$
Chipped P28 and Dyno time.... $$$$$$$ over $ 11k you do the MATH....
Dynojet showed 175 WHP & 151 WTQ on 91 octane .... That is 210HP
w/180TQ to the flywheel!!
This car is worth every penny just in parts alone / Buy it now for
Half what i spent in just PARTS!!!
Car has no problems , great daily driver or sleeper...
SHAVED EMBLEMS
Car has new PPG paint job( 2 months old) Sepang Bronze Metallic from Bmw M5
Car is complete w/Air-conditioning and Pwr steering...NEEDS NOTHING....
Most recent pics:
$$$ 6500
98 integra type-r)
SHAVED EMBLEMS
Most recent pics:
njpnoy05
Nov 11, 2011 10:44 AM
