cleaning up random parts ACT/GSR/APEXI/civic,crx,integra
Contact: PM
All parts are OBO, only trades i need are stock GSR intake(tube+box), or a running d-series engine. Shipping is available, but will cost extra. Most of this stuff will fit into a flat rate box. I am paypal certified.
Parts sold:
-Head
-Intake Manifold
-Throttle Body
-Spark Plug Cover
-Lower Timing Covers
Apexi turbo timer $50
Wicked Racing UCA's BNIB for EG/DC2
$100
Skunk2 SOHC Adjustable Cam Gear
$50
OBD1 Distributor TD-41u
$50
94-01 Integra shift linkage
$50
Ralliart Adjustable Fuel Pressure Regulator
$20
B&M Universal Fuel Pressure Regulator
$20
Hasport Eg B-series hydro to cable conversion. Allows you to run a cable trans in your hydro car.
$130
GSR Middle Timing Cover
$5
ACT Pressure Plate and cant remember what brand clutch still has life left. For B-series
$150
GSR cable transmission. the sticker has been scraped off by previous owner(s) so I'm not sure if there's another way to prove it's a GSR trans, but I used in one of my cars and can assure you it's either a GSR or B16 because it's geared short as hell. I could take off in 2nd and be in 5th by 40 MPH or so, and if I remember correctly at around 70 MPH I would be around 4k RPM's or so. It didn't grind that I remember, but it's been probably 5 yrs. since I last used it.
$300
Racing Harness Seat Belts
$30
2-inch Aluminum Radiator. Had a rough life lol but no leaks.
$50
Stock LS Air intake tube+box+filter
$40
Will get pic up soon
B-series VSS
$30
99-00 Si Upper Radiator Hose
$10
stock D-series fuel rail
$10
2001 Honda Accord DX A/T ECU *PARTS ONLY*
Make offer can get pic upon request
Assorted amp wiring w/Monster RCA wires $20
Lanzar Amp it works fine took it out of my car for a newer one.
$50
Here are some parts that I forgot to take a picture of, I can take pics if requested/interested.
OBX Mechanical Water Temp Gauge
$30
Hasport EF B-series mounts. Engine and trans mount only, no rear mount.
$100
RC 310cc injectors
$150
LS water pump looks new
$20
Passenger side CRX window. Has tint on it.
$20
Complete H22 head. Comes with cams,VC. Came off of 97-01 Prelude A/T that threw a rod out the front of the block.
$300
Remember, all parts are OBO. I will probably add some new stuff to this as I clean out. thanks for looking.
Contact: PM
Parts sold:
-Head
-Intake Manifold
-Throttle Body
-Spark Plug Cover
$100
$50
$50
$50
$20
$20
$130
$5
$150
$300
$30
$50
$40
B-series VSS
$30
$10
$10
$50
$30
$100
RC 310cc injectors
$150
$20
$20
$300
Eyal 951
Mar 9, 2014 05:04 PM
4n_intelligence
Oct 5, 2011 06:36 PM
