SI with Nav audio connections
I have searched alllll over and cant find the answer i need...
I have a amp/sub combo that i want to install into my SI-dan but want to keep the stock nav.
My question is, what audio outs does the stock nav have on them? I'm assuming that it doesnt have RCA connectors. I would like to know what it does have though...
you can use a PAC lineout converter (or any other company that makes them) to convert the connector on your factory sub into an RCA. then just hook up your amp/sub, power, ground, and find something to hook up the 12V too. i forget what i had mine hooked up to.
obviously sound quality might not be as good as using an RCA connector from the HU/Navi but this allows you to keep the factory navi and is an easy install (30-60min). JL audio and Rockford Fosgate make units to integrate your factory sound system but they are expensive and need require a lot of time for install.
Sorcin
May 17, 2010 07:36 PM
integra-modder
Audio / Security / Video
Jan 1, 2003 02:24 PM
