b18c-R spark plugs?
Old Sep 21, 2011 | 10:46 AM
colorfulej1's Avatar
Default b18c-R spark plugs?
ok i no there is aready allot of threads about this but i searched and none if them answered my question...
I have a b18c with crower valvetrain and crower stage 2 all motor cams
What would be the best plug?
has anyone ever actually dynoed to see results with plugs, because everione just says ngk platinum because it is the oem plug but im lookin for the best plug for performane and their is always something better than the oem part..wel thanks for reading give me ur best answer.
PLEASE NO BASHING
Old Sep 21, 2011 | 10:52 AM
Sunkenkarma's Avatar
Default Re: b18c-R spark plugs?
I would go with Iridium plugs, My friend with a build H22 uses them, and noticed a pretty decent increase after switching from NGK Platinums.
Old Sep 21, 2011 | 01:24 PM
Other plugs other than ngk???
Old Sep 21, 2011 | 01:29 PM
Not really, You can get NGK Iridiums xD. They have the same performance.
Iridium is the best of both worlds. Even though iridium itself isn't the best conductor, it's extremely hard. It'll last the longest of any spark plug tip material (some are rated up to 100K). Being so hard, the tip can be made to a fraction of the size of a normal one. This creates a very concetrated spark in comparison, which easily negates the lower conductivity of the metal. Iridiums are know to ignite lean mixtures that other plugs can't, which would definitely help fuel efficiency.
Old Sep 21, 2011 | 04:49 PM
Red_Army's Avatar
ngk copper.
platniums are also not oem.
its been proven to beat out iridium and platnium(both of these are for maintinenance purposes not performance. example coppers are 30k while p and I usually 100k).
its a spark plug. not a cam it makes spark. change your gap a lil.
Old Sep 21, 2011 | 04:57 PM
Deetz's Avatar
Crazy Honda Guy
Go with stock oem Denzo or NGK's....you won't go wrong
Old Sep 21, 2011 | 07:21 PM
Any effect performance?
Old Sep 21, 2011 | 07:27 PM
akacoke's Avatar
spark plugs wont give you any hp gain i believe, ngk iridium works just fine on all my faimily's cars, my girl friends sentra has them for 3 yrs 40k mile, i took em out about few month ago, they look literally like new.
Old Sep 21, 2011 | 07:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I think people on the ITR forums were talking about a heat range 7 plug. I would just either use the OEM Denso PF platinum plugs from www.sparkplugs.com (around $6.70/plug) or just pick up some $2 NGK coppers from autozone.
Iridium/platinum usually doesn't have a performance advantage. They just last longer.
Old Sep 21, 2011 | 08:35 PM
Go_Race_Your_Self's Avatar
Two Piece
Spark Plugs give you no HP gain. Platinum plugs just last longer. Just stick with NGK.
Kev
Old Sep 21, 2011 | 10:11 PM
This article states that plugs do give i hp gains and tq gains.... http://www.sparkplugs.com/sparkplug4...Results&mfid=0
Old Sep 22, 2011 | 07:27 AM
Two Piece
Do you honestly think that is true? All a spark plug does is create a small amount of spark to ignite your fuel. FUEL is what gains horsepower, not spark..
Kev
Old Sep 22, 2011 | 12:21 PM
Si!
Old Sep 22, 2011 | 03:10 PM
sweetlittlesi's Avatar
I have an ek si with a stage one skunk 2 valvetrain and i've used ngk platinums and iridiums and have noticed no difference in power. the iridiums just lasted longer. still layin down the same times at the track.
Old Dec 2, 2011 | 08:26 AM
blkej7's Avatar
So what I'm getting out of this is copper plugs have the best conductivity, whereas platinum and iridium last longer but neither increase horsepower or times.
Old Dec 2, 2011 | 04:43 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
No copper are the cheapest and last the shortest amount of time. Platinum conducts better but at a cost. Iridium work the same as platinum just last longer. New plugs may recover 1 or 2 mpg that you lost from the previous plugs. same would go as far as power. If you have noticed any increase of power it is due to you losing it
superhatchbackbros
Sep 10, 2009 10:06 AM
katzenjammer84
Honda Civic (2001 - 2005)
Jul 8, 2009 07:55 PM
93 del slo
12
Jun 11, 2009 02:02 PM
pacey
Oct 20, 2007 01:21 PM
Greg James
Aug 18, 2004 05:18 AM
