Precision News Update: New 66mm CEA Turbine Wheel - 6266 / 6766
Old Sep 21, 2011 | 07:48 AM
RealStreet's Avatar
Default Precision News Update: New 66mm CEA Turbine Wheel - 6266 / 6766
If you are currently waiting on a Precision 6265 or 6765 and being held up by a backorder, according to precision you could be in for another 3 weeks of waiting.
But dont throw your keyboard just yet. Precision announced the release of their new 66mm turbine wheels, with a new and improved design. Precision boasts a 30hp increase in power without affecting spool, thanks to the efficiency of their new turbine wheel design.
This is a CEA turbine wheel, is made by precision for precision only.
Also, more importantly, they are in stock and ready to ship, and they have all the same turbine housing options that the 65 has:
T3 in / V-band out - .63/.82
T3 in / 4-bolt out - .63/.82
T3 in / 5-bolt out - .63 with and without wg hole
T4 Tan in / V-band out - .58/.68/.81/.96
Vband in / Vband out - .82
T4 Divided .84, 1.0, 1.15, and 1.32
This means now you can get a 6266 or 6766, make more power than its 65 counterparts, spool the same (or maybe faster according to precision), without waiting, and without spending any extra money. From here that looks like a win-win-win-win situation.
Feel free to message me with any questions, or orders.
NOTE*UPDATE*:
I apologize but we were misinformed, and consequently misinformed the public. Precision has been using the term CEA to refer to their billet compressor wheels for a good time now. Boasting how the new manufacturing process provides thinner blades, less material usage, more air flow, etc. So this is what we went off of when we got word from Precision that the CEA 66mm wheel was finally available. However, Precision was able to make the thinner blades, and increase air flow and efficiency, without having to go to as expensive of a process as billet machining, and without sacrificing strength. So these 66mm turbine wheels will be cast, using a new design made by precision for precision, not billet machined. It is advertised as the benefits of a billet machined exhaust wheel without the considerable increase in cost that billet machining an exhaust wheel would incur.
High res versions of these pics, and others available here: http://realstreetperformance.com/gal...heel-6266-6766
Old Sep 21, 2011 | 07:56 AM
spectacle's Avatar
Default Re: Precision News Update: New 66mm Turbine Wheel - 6266 / 6766
Old Sep 21, 2011 | 08:46 AM
TheShodan's Avatar
Moderator
Just got an E-mail from Precision about this about 10 minutes ago. Very interesting.
Old Sep 21, 2011 | 09:58 AM
92redhatch's Avatar
Do they have and upgrade program for customers like me that have the 6765?
Old Sep 21, 2011 | 10:20 AM
Evo1's Avatar
OG Fabricator
Got the call this morning! should be great for customers...the 65 wheel has been hard to get. ...
Old Sep 21, 2011 | 10:29 AM
rs250nut's Avatar
I knew this would happen, I have just brought a bb6765 and then two weeks later this comes out
Old Sep 21, 2011 | 10:39 AM
RickyLee53's Avatar
Sounds good, wonder how reliable they'll be.
Old Sep 21, 2011 | 10:56 AM
dellas's Avatar
Same question I'm asking as I figure the cast turbine wheel would be more tolerant to heat and as a result be more durable.
Old Sep 21, 2011 | 12:21 PM
TheShodan's Avatar
Moderator
Just hang on...let's see. You may be just fine. It's like the newest iPhone.. you never get it when you want it, just because as each is released, there are 3-4 updates that are coming out soon. You never win.
Old Sep 21, 2011 | 12:48 PM
twkdCD595's Avatar
Default Re: Precision News Update: New 66mm CEA BILLET Turbine Wheel - 6266 / 6766
to Precision.
I want one to replace my 6265... just because. LOL. Seriously though, curious to see what the reviews of them are like when some get out in the market.
Old Sep 21, 2011 | 01:59 PM
0487erasmo's Avatar
Any pics???
Old Sep 22, 2011 | 11:43 AM
RealStreet's Avatar
Originally Posted by 0487erasmo
Any pics???
ok everyone please refer to the "update" at the end of the first post. We were mistaken. The "CEA" 66mm turbine wheel is not billet machined like the "CEA" compressor wheels. However, it IS made differently than the standard 65 wheel was, and offers many of the same benefits that their billet compressor wheels offer over their cast compressor wheels. For example, in the photos below, pay special attention to the thickness of the blades the the snout. Much like the CEA Compressor wheels, less material is used, thinner blades, thinner snout means less room taken up by metal, more room taken up by air, and a lighter wheel with less mass.
Old Sep 22, 2011 | 12:16 PM
TheShodan's Avatar
Moderator
Default Re: Precision News Update: New 66mm CEA Turbine Wheel - 6266 / 6766
Originally Posted by RealStreet
NOTE*UPDATE*:
.................... Precision has been using the term CEA to refer to their billet compressor wheels for a good time now. Boasting how the new manufacturing process provides thinner blades, less material usage, more air flow, etc. So this is what we went off of when we got word from Precision that the CEA 66mm wheel was finally available. However, Precision was able to make the thinner blades, and increase air flow and efficiency, without having to go to as expensive of a process as billet machining, and without sacrificing strength. So these 66mm turbine wheels will be cast, using a new design made by precision for precision, not billet machined. It is advertised as the benefits of a billet machined exhaust wheel without the considerable increase in cost that billet machining an exhaust wheel would incur.
That's what I was wondering. I knew there was No Way they could use a billet turbine shaft/wheel from the same "CEA" material as what's being used on the compressor wheel. That thing would have catastrophically failed in a matter of a few cycles. Thanks for clearing that up Real Street..
Old Sep 22, 2011 | 12:19 PM
RealStreet's Avatar
Yea I think everyones first instinct was to relate "CEA" to the "machined from a solid piece" compressor wheels. But Precisions new CEA branding stands for "Competition Engineered Aerodynamics" so that can apply to billet wheels or cast wheels, its just the term they are using for their "new and improved designs"
Old Sep 22, 2011 | 01:13 PM
racebum's Avatar
happened to me on a smaller scale. few months back i bought a 5431b with the V trim compressor wheel. month later the 5431e CEA comes out with a super light billet 6 bladed wheel that created a 50lb/min 50trim turbo.
now comes the cool part. for $75 plus shipping precision let me send back the v trim for one of the new cea turbos which i just received a few hours ago.
only catch is what you send back has to be new
Old Sep 22, 2011 | 01:33 PM
RickyLee53's Avatar
I wonder if the exhaust wheel is as light as the Garretts? I've just swapped my turbonetics exhaust wheel in my 6262 to a thinner one and saved a fair chunk from the HUGE 524g I started with.
Old Oct 13, 2011 | 10:05 PM
Casey's Avatar
what did you replace it with?
Old Oct 14, 2011 | 06:27 PM
Coheed's Avatar
Just got word that my 6262 will be here next thursday. I'll have dyno results soon after. GT3076r vs the 6262. 1.06 divided housing on the GT30r, and a .82 open housing on the 6262
Old Oct 14, 2011 | 06:40 PM
TheShodan's Avatar
Moderator
52lbs/min vs 66lbs/min? How is that a "vs."? Two completely different turbos with different needs. But good luck with your purchase.
Old Oct 14, 2011 | 08:03 PM
Coheed's Avatar
I am currently feeling uneasy about the amount of boost I run on this particular setup. the goal was to lower mid-range torque and trade it for more top end power. I felt this would be easier with the larger turbo, rather than push this turbo beyond what it will put out efficiently. Especially since I am at high elevation. I see other guys hitting high hp #s with the 30R, but not around here.
I had the option of the 35r or this... so 6262 it is. I'm hoping for 350whp on 10psi and 500whp on 20-24psi. Nothing crazy with the tune I am running. But we'll see what it does. If 450whp can be had on 22psi with a 30r, hopefully 500 can be achievable with the 6262. I only have experience with Garrett turbos, so I am interested to see what it does.
Old Dec 12, 2011 | 03:07 PM
vavoom's Avatar
I would like to know the same?
Old Dec 12, 2011 | 05:49 PM
Casey's Avatar
any comparisons yet of the 6262 old stg5 exh wheel vs the new cea exh wheel 6262?
Old Jan 14, 2012 | 11:17 AM
DA 4 Lyfe's Avatar
Bump would like to hear this also
Old Jan 15, 2012 | 01:34 PM
rayray24's Avatar
What is this 6765 or 6766?
and look how they balance it....
Old Jan 15, 2012 | 03:30 PM
TheShodan's Avatar
Moderator
That looks to be a 6-66 Exhaust wheel from the design of the wheel itself. Did you measure the exducer to confirm?
