92-95 Valve cover grommet - need only the rubber piece
Old Sep 21, 2011 | 06:46 AM
Raj-honda-tech's Avatar
Icon2 92-95 Valve cover grommet - need only the rubber piece
I have a project that I'm trying to complete and I have the following valve cover grommet, 90442P08000 (you can search under google)
which it comes with the grommet and the flange -- the grommet comes glued to the flange (same as OEM). I'm actually looking for the two pieces separate, normally they come glued. Does anyone knows where to find the grommet by itself, without the flange metal piece?
Old Sep 21, 2011 | 07:19 AM
thenext's Avatar
20% cooler
Default Re: 92-95 Valve cover grommet - need only the rubber piece
If it is on a D-series, I have a couple extras sitting around if you wanna send me a pm. You have to order them by the complete set which is $10.
Cole D
Welding / Fabrication
Mar 13, 2019 11:09 PM
d3vilishSi
Jul 18, 2007 03:33 AM
