To all "Stance Experts" i need your help
ok so heres my deal!
pretty soon im going to be purchasing a new set of JLINE wheels, which dont exactly come cheap (as some of you may no) so i need you guys opinion on what offset i should get!
So first of all, choosing an offset to me is like chinese to me, i do NOT get it!so far ive decided on 17x8, and i want some stance when these wheels are on but NOT too agressive, just somehting clean. now my buddy suggested a +25 offset ( i will be purchasing camber kits).....what do you guys think!
PIC WOULD HELP ALOT!
thanks!!
thanks!!
thanks!!
thanks!!
https://honda-tech.com/forums/wheel-tire-56/9658-forum-rules-faq-read-before-posting-1188922/
What is offset?
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. It determines how much the wheels stick out from the car. The best offset depends on your particular car as well as on the width of the wheels. As a general rule, you *should* be able to get away with an offset between +35-45, but you will have to check what others have used for your car's year, model, and version to be sure. More info: http://www.tirerack.com/wheels/tech/offset.jsp
okay so i understand offset and all that but i never thought about measuring it so i can get just what i want. so the number for offset is in what unit of measurement? centimeters right? like it would be +25cm?
If it were in cm, then +25 would be over 9.8 inches, and the hub mounting wouldn't even be inside of the wheel...
stinkypinky1011
Honda Civic (2001 - 2005)
37
Dec 19, 2007 07:42 AM
xtremecivichb
Apr 17, 2006 11:27 PM
Benjamin Tang
Jul 24, 2004 06:35 AM
