1995 HONDA CIVIC DX 5Speed Wholecar or PartOut
1995 Honda Civic DX PARTOUT or Sell Whole Car
Whole Car- $1200CASH MONEY
-CLEAN TITLE
-200k
-BLACK IN COLOR
-RUST ON BOTH QUARTERS!
-5 SPEED MANUAL Transmission
-4CYL D Series Motor
SYMPTOM OF VEHICLE
NO FUEL NO SPARK!!!
WHAT DONE TO FIX
Replaced ECU/BRAINBOX
Took To Honda Dealer Still Not fixed.. As of now its Collecting Dust!
DOES NOT RUN, Needs Either the following to RUN
-Distributor
-Timing Redone
its Something Mechanical!
PARTOUT PRICES!!!
Engine $400
Transmission $400
Engine+Transmission $600
Axles $50Each
Mounts $100
FuelPump $65
Distributor -XXX
ECU $75
Taillights $100
Headlights $100
Hood $50 (Has 3-6in dent in front of it)
Fenders $40Each
Front Bumper $85
Rear Bumper $65
Radiator $80
Condenser $75
Ac Compressor $65
Alternator $75
Power Steering Pump/Belt $70
Full Stock Exhaust $100
Cat Converter $65
Radiator CORE Support $100
Stock Springs/Shocks SET OF 4 $125
Spindle/Hub/Control Arm $125 Each Side
Door Each $65
Trunklid $65
Gas Tank $70
Filler Neck $20
Set Of Stock Steelies with Caps and Tires $140
Side Skirts Each $30 Both $50
QUARTER PANEL $100 EACH SIDE
SEATS FRONT + BACK $140
DASHBOARD $125
SPEEDOMETER $65
Windshield $95
SUNROOF $70
GAS DOOR $35
much much more
-CLEAN TITLE
-200k
-BLACK IN COLOR
SYMPTOM OF VEHICLE
NO FUEL NO SPARK!!!
WHAT DONE TO FIX
-Distributor
-Timing Redone
PARTOUT PRICES!!!
Engine $400
Transmission $400
Axles $50Each
Mounts $100
FuelPump $65
Distributor -XXX
ECU $75
Taillights $100
Headlights $100
Fenders $40Each
Front Bumper $85
Rear Bumper $65
Radiator $80
Condenser $75
Ac Compressor $65
Alternator $75
Cat Converter $65
Door Each $65
Trunklid $65
Gas Tank $70
Filler Neck $20
DASHBOARD $125
SPEEDOMETER $65
Windshield $95
SUNROOF $70
GAS DOOR $35
much much more
i need the dash harness right behind the dash. It plugs up to the fuse box right under the driver side. How much shipped to 53223. Pm me a price. Thanks
yes its from a Manual Transmission so its got a tachometer on it..
do you have any pics you can post to show you what exactly you talking about and ill give you a price shipped
how much for complete car mins swap meaning axles motor trans mounts all ac stuff ps stuff you keep everything i just want the full shell
http://item.mobileweb.ebay.com/viewi...id=45571711363
Check out that posting. The reason why I don't want to buy that one is because it's from an auto and I don't want to take the risk. Basically my harness someone hacked the wires for the headunit so I'm in need of one. It is not the harness for power conversion.
Things Included and Intact
-Dashboard
-Speedometer
-All Harnesses
-Seats Front+Back
-Center Console/Arm Rest
-ALL Exterior Body Parts/Doors/Trunk/Bumpers/Fenders Etc...
Things NOT Included
-Engine
-Transmission
-Axles
-Ac Compressor
-Radiator
-Condenser
-Mounts
-ECU
$1000 WHOLE CAR
Things NOT Included...
-ENGINE/Trans/Mounts
EVERYTHING ELSE INCLUDED, ROLLING!!!
otherwise $1200 FULL CAR EVERYTHING INCLUDED!!!
I need the shift boot, brake pedal, clutch pedal and brake booster hose that goes from booster to intake manifold. text me a price 773-610-0426.
$100 pickup
$150delivered
$100shipped
$130delivered
$70pickup for both
$100Delivered for both
$150delivered
$130delivered
Umm... No, it doesn't. And, for the record, just because the car is a manual doesn't mean it came with a tachometer. My CX didn't and clearly neither did this car. Thanks for saying it has a tach (and adding the ellipses) and then later posting pictures clearly showing there's no tach.
GLWS
GLWS
x4thGenCafe
Mid-Atlantic (Sales)
May 1, 2010 11:36 AM
99ssinoc
Jun 18, 2007 09:15 PM
