FS: Work RS Black Closed Aluminum Locking Lug Nuts 12x1.50
I am selling a full set of authentic Work RS locking lug nuts for most Honda/Acuras (and most Mazdas, Toyotas, and Mitsubishis). These were purchased brand new and do have some wear from torquing down. This is about the same wear you would see after torquing them down just once or twice. The tops of the lugs look fine and you can't really see any wear at all once mounted on the wheels.
There are 16 standard lug nuts that use a 21mm socket and 4 locking lug nuts that use a key (also using a 21mm socket). I'm including the key and a thin wall 21mm socket that should work on almost any wheel.
All of the threads of the lug nuts are in great shape and do not hesitate to easily thread onto the wheel studs. I have never used an impact gun on these, and would recommend the next owner continue to avoid that.
These are very similar to the Rays Duraluminum lugs but a heck of a lot cheaper.
$75 shipped via USPS Priority Mail anywhere in the US.
CRXSTI
May 21, 2012 02:00 PM
OneSickJDMBB6
Dec 5, 2007 09:56 AM
