Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
View Poll Results: Lighter Vs Wider
Lighter 15x7 10lbs wheels
15
75.00%
Wider 15x8 15lbs wheels
25.00%
Voters: 20. You may not vote on this poll
Wider vs lighter?
Old Sep 20, 2011 | 11:13 AM
ecko_3420's Avatar
Default Wider vs lighter?
Im looking at the performance aspect of these wheels:
15x8 15lbs
15x7 10lbs
Do i choose lighter vs wider for hpde?
Wheels will be going on a 97 civic hatchback. Thanks guys and gals!!
Old Sep 20, 2011 | 11:23 AM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Wider vs lighter?
15x8 15lbs
15x7 10lbs
Id opt for the lighter and not sooo wide.
Not sure but the wider might require you to roll the fenders.
Others with wider wheels might have more insight on this though.
If this is for hpde run what you have on it now.
Old Sep 20, 2011 | 11:34 AM
ecko_3420's Avatar
currently i have the ssr type c 15x7 which is the lighter wheel out of the 2...i've been looking it up trying to see if the 1 inch dif in width is worth the change.
Old Sep 20, 2011 | 11:48 AM
dirty19's Avatar
Ridin Dirty in Cali
Whats your experience level?
I dont think one inch in wheel size will benefit you much if you are only doing hpde.
If you go too wide you run into other rubbing issues.
But like i said I dont run a 8 inch wheel... (rules) prevent me. and I wouldnt know all there is to know about how a 8 inch wheel will fare on your car.
Old Sep 20, 2011 | 12:12 PM
JHall250's Avatar
Figure out your tire size first, then figure out your wheel size. From my experience I like pick my tire size, then pick the most narrow wheel that will properly accommodate them.
245/40R17 on a 17x8
225/45R15 on a 15x7
205/50R15 on a 15x6
Generally having more sidewall flex reduces steering precision/reaction but increases overall grip and consistency. My 2 cents
Old Sep 20, 2011 | 12:56 PM
Ghetto Civic HX's Avatar
I love to drive
If I were you I would use the 15x7 because you already own them. Until they start crowning HPDE champions the weight vs wide debate isn't really an issue.
I've done HPDEs on wheels from 6" to 7" wide and weighing up to 17lbs and I had the same amount of fun on all of them.
Old Sep 20, 2011 | 05:31 PM
lwnslw's Avatar
What tire size are you going to run? And how much lighter are the 8" wheels?
Old Sep 20, 2011 | 05:33 PM
lwnslw's Avatar
Sorry just saw the difference 20 lbs for all 4 in hpde, don't worry about it. Just run what u have.
Old Sep 20, 2011 | 06:22 PM
ecko_3420's Avatar
Thanks guys!!!im cuurently using kumho xs 225/45/15 on my ssr but just pickd up a set of toyo r888 frm another post on here...i guess ill be sticking to my current set up.
Old Sep 22, 2011 | 10:56 AM
Davidss's Avatar
Are you sure they are 225s? I don't think they are available in that size.
Old Sep 22, 2011 | 12:27 PM
JHall250's Avatar
Hankook RS-3's are offered in 225/45R15. If it wasn't for the R888 sale that's what I was going to get next.
Old Sep 22, 2011 | 01:11 PM
ecko_3420's Avatar
Sorry my mistake!!it was the 205/50/15 for the toyos..i wanted to get tge rs3 too but the toyos are such a good deal i couldnt pass itup!!
Old Sep 22, 2011 | 01:18 PM
Egezzy's Avatar
Spongebrad Squarepants
this.
and..
you still haven't answered the question. my guess is you don't have much, if any experience. if that is the case, i would highly advise you not to run the triple8s. but, i guess if they have been purchased, it is too late. you will learn more on a "lesser" tire where you will/might find the limits.
Old Sep 22, 2011 | 01:32 PM
The Destroyer's Avatar
Originally Posted by Egezzy
this.
But that grip.
Run what you have, and if you need another set of tires grab another set of Kumho's as they tolerate heat well & are cheap.
Old Sep 22, 2011 | 01:38 PM
Egezzy's Avatar
Originally Posted by The Destroyer
But that grip.
..it seems endless!!!! lol.
Old Sep 22, 2011 | 01:49 PM
ecko_3420's Avatar
I have done numerous autocross as well as hpde events..the 15x8 wheels have not been purchased,jst tires (toyo r888 in 205/50/15)...i am close if not at the limit of the grip on my current set up and thus why i am venturing out to the 15x8's...but i will continue to run these because of the tire sale..unless theres a set of 6ul thats too good to pass up.
Old Sep 22, 2011 | 01:50 PM
ecko_3420's Avatar
Thats what a couple of my buddies are tellig me!!
Egezzy's Avatar
you will get more out of tire width than rim width.
ecko_3420
Sep 20, 2011 09:04 AM
RNbuilt
Jun 16, 2008 12:03 PM
snowfro21
Nov 14, 2006 04:13 PM
rob_d16y8
Jun 15, 2005 01:24 PM
