800hp Civic hatch part-out!!! Everything is for sale.
Old Sep 20, 2011 | 07:50 AM
Russyo's Avatar
Default Fully built GSR head. Complete SUPERTECH Valvetrain, ported and polished!!!!!!
SOLD SOLD SOLD!!
SOLD::
-Full blown dual pump hanger, 2 walboro 255 pumps, -8 feed and -6 return, 100 micron fuel filter near fuel rail, Weldon FPR. - $600 sold to dropped93ex
-ID2000 injectors $650 Sold to Cimburke23
-Victor X GSR intake manifold $200 sold to violetpearlgsr0
-Clutch Masters twin disc for B-series hydro trans kit. Flywheel, pressure pate, discs, throw out bearing. Has maybe 1000 miles, only highway pulls and dyno time $750 Sold to CiViCgSr7
-AEM wideband kit, gauge and sensor $100 SOLD
-Hondata boost solenoid with mounting bracket $50 Sold to 13g-CRX
-Omni 4bar map sensor $50 Sold to 13g-CRX
-Basset 15x8 4" back spacing 4x100 (x2) w/ MT ET Streets 275/50-15 radials $350 OBO Sold to JDMegCoupe765
-Hondata P72 s300 w/ all boost options $550 Sold to Mark
-GSR dual gauge pod for cluster $20 Sold to H22ftw
-Mini-ram manifold with T4 flange, both wastegates included with manifold. $450
-ITR cams with stock cam gears sold to B18C1EJ6
-Shell - 92 Civic hatch CX 5spd. Sold
-B18c1 GSR block, GE 84.5m, sleeved/o-ringed block. JE 9.4:1 T1 pistons, Manly I-beam rods, honda bearings, Balanced/micro polished LS crank. $2500 Sold to JDM346
Precision PTE 6765 T4 .96 hotside undivided turbo. Less than 1k miles. $750 Sold to Skinny Will
Traction bar. Used but MUCH better quality than an eBay version. $150 shipped SOLD
Dual Core half size radiator w/ high speed electric fan $100 Shipped SOLD
2.5" intercooler piping kit w/ eBay SSQV bov, comes with t-bolt clamps and couplers. $100 Sold to Tams4511
Liquid Metal 15x7 +38 offset 4x100 rims (x4) $250 OBO Sold to MetalSlug
GSR HYDRO transmission perfect working gear set with cracked case $250 (pics below) SOLD!!
T1 vacuum block $25 SOLD!!!
Intercooler w/ 3" piping, couplers, and t-bolt clamps. SOLD!!!
GSR HYDRO trans w/ upgraded OBX LSD, flawless shifting!!! No scratches and no pop-outs!! SOLD!
Tial 50mm bov, blue. Comes with flange and clamp $200
GSR p72 fully built head. $700 firm SOLD
Block: 99 GSR block w/ less than 1000 miles. $2500 SOLD!!
Golden Eagle Sleeved and o-ringed
Micro polished and Balanced LS crank
Manley Turbo-tuff I-beam LS rods w/ arp 2000 rod bolts
JE pistons (T1 custom) 84.5mm
It was assembled with all OEM honda bearings (PINK)
OEM GSR/TypeR oil and water pump
Used an OEM honda timing belt, and a Golden Eagle 84.5mm OEM head gasket.
Still has catch can drain back fittings installed, and the stock catch can plug.
All machine work was done by Cains Autohaus (machine shop) in Plano, TX
It is fully assembled, ready to join with a head and slap in!!!!
The motor was broken in by T1 on their dyno. Used Sae30 Brad Penn break in oil and a k&n filter for the break in. Then the oil and filter were changed by T1 to 5w20 Brad Penn racing oil and a k&n filter before tuning. After 500 miles the oil and filter were changed again, this time using Royal Purple 5w20 and a Fram Tough-Guard filter still on the block now.
Old Sep 21, 2011 | 05:24 AM
Russyo's Avatar
Default Re: 800hp Civic hatch part-out!!! Everything is for sale.
Bump.
Old Sep 21, 2011 | 07:12 AM
Russyo's Avatar
Fuel system sold, still have the ID2000's though.
Old Sep 21, 2011 | 12:07 PM
Russyo's Avatar
Bump. Car is currently running if anyone wants to see it run as is, or needs pics/vids just ask!!!
Turbo, motor, setup will make 800 pretty easily!!
Old Sep 21, 2011 | 04:19 PM
Russyo's Avatar
Pm's replied.
Old Sep 22, 2011 | 05:18 AM
Russyo's Avatar
Bump small stuff is moving. OBO is listed on bigger parts, I'm taking offers!!
Old Sep 22, 2011 | 11:34 AM
Russyo's Avatar
Bump.
Old Sep 22, 2011 | 10:26 PM
Russyo's Avatar
bump
Old Sep 23, 2011 | 05:16 AM
Russyo's Avatar
Bump.
Old Sep 23, 2011 | 12:45 PM
Russyo's Avatar
bump. Pm for questions/requests.
Old Sep 23, 2011 | 01:28 PM
1qwkinline4's Avatar
Do you have mounts, solid swap style?
Old Sep 23, 2011 | 01:30 PM
Russyo's Avatar
mounts will go with the shell. I don't think they are solid, I'll have to check which they are.
Old Sep 24, 2011 | 08:52 PM
Russyo's Avatar
added pics and updated list of sold parts.
Old Sep 25, 2011 | 05:54 AM
13g-crx's Avatar
What map sensor were you using and is it available. Package deal with the boost solenoid?
Old Sep 25, 2011 | 10:50 AM
Russyo's Avatar
Omni 4 bar map sensor it is available for $50. PM'd.
Old Sep 26, 2011 | 05:24 AM
Russyo's Avatar
Parts are pulled off the car, list should be up to date now. Most parts paid for are shipped, one more to go out tonight or tomorrow morning once motor is pulled tonight.
Old Sep 27, 2011 | 07:07 AM
Russyo's Avatar
Bump to the top, selling stuff all day long!! PM for questions or pic requests!!
Old Sep 27, 2011 | 11:39 AM
Russyo's Avatar
Bump added some more details about the shell.
Old Sep 27, 2011 | 04:43 PM
Russyo's Avatar
Bump it up. Package deals can be made, just ask.
Old Sep 28, 2011 | 05:19 AM
Russyo's Avatar
Bump.
Old Sep 28, 2011 | 05:46 AM
surfnaked619's Avatar
I want your GSR seats how much for the front?
Old Sep 28, 2011 | 06:23 AM
Russyo's Avatar
Pm'd.
Old Sep 28, 2011 | 07:10 AM
Dakota's Avatar
how much for the duckbill?
Old Sep 28, 2011 | 07:13 AM
Russyo's Avatar
$100 shipped.
Old Sep 28, 2011 | 11:09 AM
Russyo's Avatar
Bump, pm's replied.
