Cleaning Garage - K series stuff
I have for sale some K series stuff left over from a cancelled project. I take paypal unless otherwise noted. Send me your best offers.
Brand new - Drag Cartel k24 2.7L drag race block. 106mm stroke 90 mm bore, 15:1 CR pistons. oil passages coated for maximum flow. Brand new k24 core, ERL machined assembled. - $6000 cash/money order + shipping
ARE dry sump kit, comes with tank, 3 stage pump, oil pan, ATI race damper k20/k24, oil catch can, oil filter relocation, adapter to ATI race damper for drive gear. You will need to create a bracket ( i can provide the aluminum bar) to mount the oil pump. Then you will need to call ARE tell them distance between pump and crank shaft so you can get the right drive belt and gears. You will also need the adapter for feeding the oil to the engine where oil filter is located. I paid dealer pricing which is $3200... OBO
Custom machined hubs that fit OEM RSX-S wheel bearings. so you can make your own knuckle for your full race car. CNC machined out of chromoly steel. - $100
K20a2 valve springs retainers and seats - OBO
5 speed main shaft 50k mi on tranny- OBO
1 piece front end 02 civic coupe - OBO
5 speed shift forks - OBO
5 speed 3rd and 4th gear, and synchro hub from main shaft - OBO
5 speed 5th gear and synchro hub from main shaft - OBO
5 speed reverse gear - OBO
5 speed reverse shift mechanism - OBO
5 speed shift arm - SOLD
5 speed 1st and 2nd gear and synchro hub from counter shaft - OBO
5 speed 3rd, 4th, and 5th gear from counter shaft - OBO
Justin Jones
Dec 8, 2009 02:52 PM
Turbo-charged
Mid-Atlantic (Sales)
10
Feb 3, 2009 10:31 AM
