2000 Integra SE power door lock conversion
What's needed to convert this car to have power door locks, do I need to switch the floor harness or can I keep the existing one?
Anyone with experience please respond.
Thanks,
Thanks,
SE comes with power locks, RS is only model I know that doesnt, either way the subharness should be the same just need the door harness's switches and trims
Just install the Audiovox PRO PDL-2 it comes with everything you need, the actuators are "5 wire" so the stock door lock switch becomes the power door lock switch and you get "central locking", [locking or unlocking either door with the key or lock switch will lock/unlock both doors.
The module has inputs for key-less entry.
If you want to go OEM you will need the door latch/actuators the door harnesses and the door lock switches, not sure if you need a dash harness or not, maybe just a fuse for the fuse box. 94
No. The SE was a GS.
from the FAQ:
https://honda-tech.com/forums/acura-integra-6/all-gen-integra-%5Bfaq%5D-diy-write-ups-how-etc-2419202/
from the FAQ:
Specific Model information
Integra RS (discontinued after 1998): No abs, No moon roof, power windows,power door locks are an option, came with cloth seats
Integra LS: (luxury sport) Came with power door locks, sun roof, power windows, Has ABS, The LS also came with cloth seats
Integra SE (special edition): (only available in 1995/1996 which is basically the integra GSR without the suspension and engine upgrades) Comes standard with leather, moon roof and all power options
Integra GS (grand sport) the "twin" of the SE but wasn't released until 1997.. Basically the GSR without the engine & suspension (comes standward with all power options and moon roof)
Civichatch972
Dec 31, 2002 10:27 PM
