AEM Series 2 EMS for Acura Integra GSR 1994-1995 AEM Part#30-1040
selling my aem ems. bought it from aemonly.com. only used it once for my h2b swap. I would like to sell it for 1000obo. no trades, cash only. This is the same information you get from the website.
AEM's Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, as noted below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
Plugs directly into the factory harness. No rewiring necessary.
Uses all the factory sensors.
Includes start up calibrations.
System is fully enabled and unlocked - Never pay for upgrades!
Context sensitive help eases tuning process.
Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
Runs on Windows-compatible software.
12 peak and hold injector drivers (Supra only).
8 direct-fire coil outputs.
16 general-purpose outputs.
8 definable switch inputs.
4 EGT inputs with fuel control.
1MB of internal data logging.
Electronic boost control.
Full idle control.
Programmable traction control.
Software definable knock control.
Two step launch control.
User configurable soft-cut rev limiters.
Wet or dry nitrous control.
Tune using new USB communication port or serial port.
Works with all AEM gauges.
If you have any questions, email me at marine0621usmc@yahoo.com. thank you
Full idle control.
