tokico spring performace affected after being cut?
hey ht. well i bought a set of tokico springs i will post the exact model number later. i installed them on kyb shocks and the drop on the rear was perfect but in the front the tire had 2 fingers gap from the fender. I was thinking since its just like an extra inch drop i would like, i can just slightly cut the front springs without drasticly affecting the performance of the spring. i know it will affect it in some way but will it totally mess up the ride?
thanks in advance for the help.
So you drop somewhat decent money on some springs just to cut them? Stay far away from it, don't do it. Unless you want to make your car ride horrible.
These kinds of threads inquiring about unsafe practices should not be allowed. They don't allow any threads concerning stretched tires in Wheel and Tire for that reason. This forum should start adopting a similar stance.
You would be surprised...
http://rat-look.com/image-gallery/ng...-look-2/honda/
I'm not referring to a "look". Seen it. I'm talking about trying to apply practices used on antiquated technology on more modern vehicles. It doesn't work.
And I am saying that on a STOCK spring, it has been successfully done. I know, I have seen it been done. I am saying AFTERMARKET springs shouldn't be cut. A car made in 1995 doesn't exactly have modern technology built into the suspension.
That would be nice if honda made it's springs that way, but they don't. The real problem with safety in cutting springs is that the "perch" isn't correct. The spring doesn't seat properly into the shock.
And unless you're a blacksmith you're going to have a tough time reshaping the final coil of the spring so that it does fit in the perch.
i think that your wrong because people like me create these threads to be safe and not just go ahead and do the "unsafe" practices. i try to do my research and get different opinions on the matter so i can make the right decision and not risk my life or other people's lives.i mean it would be different if my heading was " how can i cut my springs?" but im just wondering what will be happen if i cut them.
I don't think you can qualify yourself as being unique in that you want to do dangerous things more safely. The principle is still the same.
That's like saying: "I'd like to jump off a cliff, but if I wear a helmet and knee pads it's better right?"
GR2's don't have very advanced valving as they are more "oem replacements" than designed to handle stiffer rates. By cutting your springs you're likely to blow the shocks. Then you'll be back here asking which shocks to buy to go with your cut springs.
Save up your money, and buy a real suspension kit. Progress CS-II, Koni Srt. + spring/sleeve of your choice, Koni GC, AMR, PIC, there's a host of companies I'd recommend.
Eibach also has several kits, prokit, sportline, etc.
This method used to be used in the 80s when there was no technologies!!go a head you won't be the first,,,and see why evolution takes place and why retards need special ed!!
And also lmfao on no technology in the 80s. I forgot the stone ages were that long ago.
OP, YES the thicker springs should be in the front.
There's more weight up there
Tokico springs are designed this way.. IDK why, they just are. I had a set and the same stance happened to me...
sell that set up asap and get some coilovers. youll be alot happier and safer
