rearmain seal woes
well i finally got my car finished. after a long wait. the rear main seal was leaking. so i pulled the trans and replaced the seal. on the first 5 miles of driving my flywheel came loose somehow. wel i am so tired of working on this car, i decided to send it off to joey songer @ raceworks ( http://www.lockracewrks.com ) he has an abundance of knowledge including 15+ years of honda factory tech experience under his belt. well i had my car towed to him, knowing his qualifications i knew there woudlnt be any problems with the fix. he called me up about 4 hours later to tell me everything went smooth and to tell me a few little things tha were wrong, that he fixed for me. for al you EF owners out there, he has a fix for the main relay, and he promises its a permanant fix to the failure common with those pieces. he also did that ofr me while it was up there. when i went to pick my car up, i had no idea what caliber this shop is. he has full race cars sitting everywhere, including rodger foos old EG skunk2 hatch!!
as well as quite a few other race cars. i highly reccomend this place to anyone if they need work done, have a motor that needs installing, or anything aftermarket installed, if your located in GA. my car drives great and no more leaks!!
[Modified by johnzm, 10:52 PM 10/4/2002]
as well as quite a few other race cars. i highly reccomend this place to anyone if they need work done, have a motor that needs installing, or anything aftermarket installed, if your located in GA. my car drives great and no more leaks!! [Modified by johnzm, 10:52 PM 10/4/2002]
