Need help on skunk2 pro series manifold for 97-01 prelude
Old Sep 18, 2011 | 06:08 PM
Mugenboij's Avatar
Icon6 Need help on skunk2 pro series manifold for 97-01 prelude
So I have it installed and everything but can't get the car to start. So basically I want to start over but need to know what I can bypass and what I can't. Right now the car is running on a p28, I didn't use the egr valve and I moved the IAC valve to the back of the manifold instead of connecting it to the fuel rail,( know its a tight fit but I couldn't get the hoses to sit right). I did have to rewire and extend some cables but I think its right now but still I'm not sure, I already took it out 3 times. So if anyone has some knowledge to lend I would love to hear it....also its a PDE stamped H23A with a obd1 distributor an a 98 shell
Old Sep 18, 2011 | 06:32 PM
typemismatch's Avatar
Honda owns me
Default Re: Need help on skunk2 pro series manifold for 97-01 prelude
Post pictures
Old Sep 19, 2011 | 01:19 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OBD1 distributor? So internal coil? Did you wire up the crank angle sensor so that the distributor would run the timing and fuel?
Old Sep 19, 2011 | 04:07 AM
minilogoguy18's Avatar
^OBD1 USDM are external.
Old Sep 19, 2011 | 05:42 AM
Mugenboij's Avatar
Old Sep 19, 2011 | 05:45 AM
Mugenboij's Avatar
Old Sep 19, 2011 | 07:45 AM
Mugenboij's Avatar
With a p28 can run the car with out the egr valve?
Old Sep 19, 2011 | 08:36 AM
Honda owns me
Its a chipped P28?
It would run without the EGR, I have mine blocked off using my stock P13.
Did it run before you put the intake on, it looks like you had the motor out? Is this a fresh swap?
Old Sep 19, 2011 | 09:32 AM
nus_dogg's Avatar
The stock p28 doesn't support EGR.
Old Sep 19, 2011 | 10:49 AM
Mugenboij's Avatar
Yeah it ran before I swapped it in. I needed a transmission but decided to get the s2 also
Originally Posted by typemismatch
Its a chipped P28?
Old Sep 19, 2011 | 10:57 AM
Mugenboij's Avatar
Thought so. But do I have to plug in the sensors for it? I just removed it completely and took out the wires from my harness
Old Sep 19, 2011 | 02:14 PM
If you are running a chip that allows you to disable the egr and retune you will be fine.
Old Sep 19, 2011 | 02:23 PM
Honda owns me
The only way that removing the EGR from your harness would cause an issue is if you removed a shared ground wire that is run in series with other sensors.
Missing EGR on an ECU that supports it throws a CEL but doesn't affect the drivability, at least not that I've noticed.
Old Sep 19, 2011 | 02:54 PM
Mugenboij's Avatar
I did something like that....the green wire with the black line running down the middle I completely removed it from every sensor
Old Sep 19, 2011 | 02:57 PM
Mugenboij's Avatar
I'm thinking and hoping that I might just need a new wire harness but still I can't figure out what's going on. It cranks but it wont ignite, it caught a few times like it was about to start but it played me
Old Sep 19, 2011 | 05:05 PM
Honda owns me
Have you tested for spark at the spark plug? Fuel at the fuel rail?
Start there.
If you removed the common ground on all your sensors ...
Old Sep 19, 2011 | 05:07 PM
Honda owns me
I have a spare OBD2 H22 engine harness
Old Sep 19, 2011 | 05:28 PM
Mugenboij's Avatar
Yes I tested for spark....the fuel pump also turns on fine but I haven't actually checked the fuel lines.
Start there.
How much do you want for the harness?
[QUOTE=typemismatch;46044286]I have a spare OBD2 H22 engine harness
Old Sep 19, 2011 | 06:04 PM
Honda owns me
Do you have spark?
Do you smell fuel? Pull a plug out, check for wetness and smell in the cylinder. You can have fuel pressure and no fuel, if your injectors aren't opening.
Old Sep 20, 2011 | 06:43 AM
Mugenboij's Avatar
Ok thanks ill try that out today
Do you have spark?
Old Jun 16, 2012 | 09:57 AM
Mugenboij's Avatar
found out it was my distributor and a bad battery
dfanatic86
Mar 5, 2014 05:23 AM
ogmudbone
Mid-Atlantic (Sales)
Sep 20, 2009 08:06 PM
djsire
Mar 21, 2006 12:43 PM
SupraRXZ
Feb 15, 2006 09:20 AM
