ctr cams with ctr cam gears in my b18c1
Old Sep 18, 2011 | 03:04 PM
crazihobo's Avatar
Default ctr cams with ctr cam gears in my b18c1
im putting ctr cams with stock ctr cam gear into my stock b18c1 1994 125k.. and im wondering am i going to need new valves retainers springs? im not plannign to rev higher then 8.5k..
im wondering how much power ima putout in total?
i have
skunk2 manifold
intake
68mm throttle body
headers 2.25
itr pipping 2.25
and will have ctr cams+ getting my ecu chipped.
whats the estimate power to the wheel?
Old Sep 18, 2011 | 03:47 PM
GagnarTheUnruly's Avatar
Default Re: ctr cams with ctr cam gears in my b18c1
People run stock valvesprings with CTR cams but I've looked at the specs and I'm not a fan. At the very least get ITR valvesprings for the intake cam and move the GSR intake springs to the exhaust valves. Retainers should be OK at 8.5k. Power will be similar to a stock ITR.
Old Sep 18, 2011 | 05:07 PM
crazihobo's Avatar
really i dont think ima put out the same power as itr. considering itr does have itr pistons and mild port head.
Old Sep 18, 2011 | 06:43 PM
NemesisCBR's Avatar
same recommendation as gagnar.. you can run them without changing some of the valve train but youre better off at least doing the itr valve spring change. I just did it for the peace of mind and reassurance that they have the proper springs for the cams. Its a question of what risk factor youre willing to put your money on.
You should still be close to itr power with the mods you have. If youre motor was healthy before you would be putting down between 140-150whp before upgrades. You asked for an estimate and 'close' is about as good as you can get without a dyno. Are you getting chipped and tuned? If not just do a dyno run at a local shop. Youre in la so head over to raceline in temple city. Should be around $75 just for a dyno graph.
Old Sep 18, 2011 | 08:33 PM
mouab18c1's Avatar
You'll be fine if you keep the rev limit of the b18c1 to be safe. I had 00 ITR on my stock GSR head for 3 years revving to 8500rpm.
Old Sep 19, 2011 | 12:41 AM
crazihobo's Avatar
wells i'm gonna get my ecu chipped at eriks racing they sed they gonna check my timing and if i get enough fuel or not.. kinda like a mini tune?
Old Sep 19, 2011 | 02:21 AM
rhymeshark916's Avatar
Doesn't mean it's "safe".
Old Sep 19, 2011 | 08:46 AM
crazihobo's Avatar
wells i'm gonna keep my rev limit at 8.2k i would like to go 8.5k but seems a littlee risky.
Old Sep 19, 2011 | 11:26 AM
Canadiangsr's Avatar
Quick question are ITR/CTR cam gears really required? Please keep us updated after you install your cams and a tune
Old Sep 19, 2011 | 01:16 PM
doood's Avatar
been there done that
No
Old Sep 19, 2011 | 03:53 PM
crazihobo's Avatar
alrite wells erik at eriks racing wasnt here today so i'll keep it posted and tell you how it feels i prolly won't get it dynoed till.. later on tho.
Old Sep 19, 2011 | 09:13 PM
NemesisCBR's Avatar
I need to stop by there and ask them about a ecu i have with his name on it.
Arent the cam gears for itr the same as stock gsr anyway?
Old Sep 20, 2011 | 04:07 AM
crazihobo's Avatar
Haggai think they are the same thing
Old Sep 20, 2011 | 12:50 PM
crazihobo's Avatar
uppp! didnt get to do it..prolly cant do it for antther week i got homework..
Old Sep 20, 2011 | 08:53 PM
mouab18c1's Avatar
Doesn't mean it's not possible.
Old Sep 21, 2011 | 09:26 AM
crazihobo's Avatar
just called.. eriks racing. they sed its fine to rev up to 9k. and won't have any problems. lol thats with stock gsr valve springs and retainers. but gonna need a valve adjustment.
Old Sep 21, 2011 | 09:35 AM
Sure.
Old Sep 21, 2011 | 09:36 AM
Bs. Haha. Rev to 9k on stock vt. You will float your valves and more. I'll tell you that.
Old Sep 21, 2011 | 09:37 AM
doood's Avatar
You won't make power that high. So why do it?
Old Sep 21, 2011 | 10:51 AM
Don't go back to that shop. Running CTR cams on GS-R springs is iffy for multiple reasons, but possible. Running up to 9000 is NOT POSSIBLE on stock springs or retainers.
Old Sep 21, 2011 | 11:03 AM
mouab18c1's Avatar
Like I said 8100 rev limit. You'll be fine all day.
Old Sep 21, 2011 | 11:10 AM
crazihobo's Avatar
lol. i'm just planning to rev it to 8.5k so yeah. i know it doesnt make any more power then that. wells is reving to 8.5k cool? i found some b series crower valves springs and retainers for 100. not sure if i should buy it yet. i won't be reving it to 9k for sure. setting my rev limiter at 8.5k i should be shifting around 8.3-8.4k how does that sound?
Old Sep 21, 2011 | 04:08 PM
sc34dc4's Avatar
Stiffer valve springs and retainers and a good idea weather you're revving to 8,100 or 9,200. Why spend all that money to float a valve and possibly destroy your head? Doesn't make any sense.
Old Sep 21, 2011 | 10:00 PM
NemesisCBR's Avatar
The concept is simple. The higher you want to rev on a stock valve train the greater your risk of screwing something up and the higher you go the closer you get to 'when' not 'if'. Every persons mileage will vary because each persons parts are in different shape so you have stories of so and so who drove for 4+ years so far no problems and then you have another guy who blew his motor in 2.
Go with the recommendations or choose your own risk factor. I chose to go with itr intake valve springs and move my gsr intake over to exhaust side for itr cams. Ill know where i can rev to when i get it dyno'd. It did not cost much more for the peace of mind but it did take more labor.
Old Sep 22, 2011 | 12:18 AM
DBiNfEcTeD*'s Avatar
^+1
