90 honda accord problem
Old Sep 18, 2011 | 02:18 PM
cholder919's Avatar
Default 90 honda accord problem
I changed the fuel filter it was very dirty and black at the bottom but a problem still occurs when the car gets under half a tank. If I slam on brakes the rpms drop to zero and the cars shuts off but If I hit the gas real fast I catch it from cutting off but If I ease on the brakes the car doesn't cut off. Can the fuel pump be clogged with dirt...
Old Sep 18, 2011 | 03:37 PM
cholder919's Avatar
Default Re: 90 honda accord problem
with the car in park I seen the rpms go to 2 then drop to 1 costantly, the car is reving up and down just sitting there
Old Sep 19, 2011 | 08:06 AM
StreetsideStig's Avatar
Get a fuel pressure gauge and screw it into the top of the fuel filter. I believe it should sit at 40-50 psi.
Old Sep 19, 2011 | 05:41 PM
Lost Again's Avatar
Clean the IAC......check the coolant level. Check the FITV, a reach in that, then clean the heck out of the TB,,,,,pay close attention to the two ports on the firewall side of the tb,,,,and also be sure to clean both sides of the butteryfly.
Old Sep 19, 2011 | 05:43 PM
joeshmo's Avatar
There is most likely a fuel pickup sock that could be clogged with dirt. Seems odd that it only does it after half a tank though.
vegava
Oct 6, 2012 12:10 PM
cholder919
Sep 30, 2011 06:58 AM
jeebus520
Jul 9, 2010 10:15 AM
Dropped90Integra
Jul 26, 2005 05:09 AM
Jeff
Mar 26, 2004 08:14 PM
