4g63 custom intake manifold
Old Sep 17, 2011 | 09:39 PM
Golfball's Avatar
Default 4g63 custom intake manifold
i decided instead of buying one that i would never be happy with i wanted to build my own crazy one that no one else would ever have... Anyways heres what went down. im happy with it weather it makes power or not. I just like having unique parts and i just enjoy fabrication.
stared with a stock manifold
chopped off the runner
removed all the extra brackets and unsused sections
chopped out the the part where the runners gonna fit
threw it on my bridgeport and machined it out a bit.
befor
after
then started welding er up.
SIDE NOTE, i had a bug land in my bead as i was welding, teach me to weld a night with the garage door open lol
couple of weld close ups (please not i have only been aluminum welding for about 2 weeks so i still have a lot to learn, my biggest problem currently is dipping the tungsten and consistency)
all put together.
on the car
used my the mill to make a throttle body flange to couple it to a 76 mm GM throttle body
Some finished pictures
then lastly i used my stock Mitsubishi throttle body and chopped off the idle control motor to make a remote mount throttle control unit that will plug into my stock wiring harness but still allow me to use the larger 76 MM GM TB.
stay tuned for a crazy *** exhaust turbo manifold.
Old Sep 17, 2011 | 09:58 PM
TrackMasters_AZ's Avatar
Default Re: 4g63 custom intake manifold
Next you should buy a flange and try one from scratch!!! Good job though
Old Sep 18, 2011 | 05:34 AM
russianvr4's Avatar
OG Fabricator
that looks pretty slick josh!
Old Sep 18, 2011 | 09:59 AM
gehlSRT's Avatar
looks good for a first try ! good job
what wleder are you using ? Also how far is ur tungsten sticking out ?
biggest thing with consistency is geting both of your hands comfortable, atleast with me. i like to rest my pinky finger of my torch hand on my material (it helps if you have a thicker glove) and kinda use that to slide along your piece. itll help keep your torch steady
Old Sep 18, 2011 | 05:49 PM
russianvr4's Avatar
OG Fabricator
hes using a sync 200
Old Sep 19, 2011 | 12:00 AM
Golfball's Avatar
yeah its a syncrowave 200 sadly with just an aircooled torch .
using pure tungsten sticking out about 1/8 inchish.
the biggest problem i was having causing it hard to be consistent is im having to use my cloths dryer plug to power the welder and so it pops the breaker about every 3-4 inch's of weld at 115-120 amps. literally if i try and go up to 130+ amps it makes it about an inch of weld. WEAK.
Old Sep 25, 2011 | 08:13 AM
SpeedwayCoating's Avatar
Get this fixed and you will be way happier with life.
I had a bad breaker on my welder's circuit at one point, and right in the middle of everything it would trip, this can be a huge pain!
egycasper
Welding / Fabrication
Dec 22, 2017 11:35 AM
Thrasher96
Nov 22, 2015 05:39 PM
Tony the Tiger
50
Apr 8, 2005 05:46 AM
roydogg
Apr 15, 2004 03:37 PM
