power window problem
Old Sep 17, 2011 | 03:09 PM
tourbo24's Avatar
Default power window problem
I have a little problem that has been bugging me for a while now. The passenger side window doesn't seem so close all the way up and you can hear a lot of air noise while driving on the freeway. I have also noticed that when I put the window up it kinda jumps like its loose or something. Before I tackle this problem, are there any parts that i should buy or could it be that some bolts got loose and i just need to tighten them up?
1999 accord coupe ex v6
edit: took the door panel off and even took the window out and i still cant figure out what is wrong. when i put the window back in, it doesnt even go all the way up, it stops about an inch from the top and i have to push it up with my hands. also when the window is pushed up all the way, i can hear the motor spinning but nothing moves. does anyone have any idea of what might be going on? seems like something needs to be adjusted, but i have no idea what..
Old Sep 18, 2011 | 05:31 AM
Lost Again's Avatar
Default Re: power window problem
Sounds like the regulator is bad or not adjusted properly.
Old Sep 18, 2011 | 04:23 PM
purgat0ry's Avatar
I have the same issue currently, I know the problem, just need to fix it...
Your window regulator is either going bad OR you need to open the door, bring your window down so you can see the bolts, have a friend raise the window up (it should only move a smidge) and tighten the bolts that hold it into place.
Cake fix, just time consuming.
Old Sep 18, 2011 | 08:06 PM
75aces's Avatar
Is the weatherstip binding at all? I would check the end that goes into the window channel. I noticed on my 96 sedan that the ends only goes +/- 1/2 way down. If it's not seated properly, then it can create a seal issue when the window is closed.
Old Sep 18, 2011 | 10:04 PM
slomofo's Avatar
GDD Member
Regulators are cheap, change it and be done with it.
Old Sep 18, 2011 | 10:12 PM
socalcd6's Avatar
same problem here bro .... its most likely ur window regulator is going bad... mine goes really slow going up adn down and when going up it gets stuck half way ..and i haev to pul it up with my hands a lil... changed the regulator and it worked fine.... hope it works for you bro ..we all hate that air sound lol
Old Sep 19, 2011 | 06:57 AM
75aces's Avatar
Sometimes its not the regulator. Try operating the regulator with the glass out. When the glass can't move in the weatherstrip properly, it will get off track and won't close. I wan putting my rear door back together recently and noticed that when the weatherstrip wasn't seated properly the glass didn't go all the way up. Just double check.
jessihall
Sep 6, 2010 11:45 AM
stevenkha
Mar 12, 2009 08:13 AM
nomoshing
Aug 6, 2008 10:53 PM
jhec23
Aug 26, 2006 07:10 PM
