brakes and funny noises
What Kind of pads did you use ? were they cheap or expensive ? Some times cheaper pads will always have increased pad noise. Most shops will waranty the pads if you tell them whats going on atleast I would. Is there any vibration or just noise ?
So, new pads, old rotors, and probably didn't get them turned? Try performing a proper bedding procedure and see if that corrects the noise. If that doesn't work, try deglazing the rotors with sandpaper and then re-bed them.
