bleeding the clutch
Old Oct 4, 2002 | 12:23 PM
kuelerz's Avatar
Default bleeding the clutch
how do you blead the clutch, after i did my sway the pedel is full of air?
Old Oct 4, 2002 | 10:30 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: bleeding the clutch (kuelerz)
same way you bleed your brakes.
Pump 3 times, open bleeder, close bleeder, pull pedal up off floor. Not too fast so the clutch MC can fill from the resivoir. KEEP a close eye pn the fluid level, it will drop faster than you think, leaving you to do everything all over AGAIN
Old Oct 5, 2002 | 01:47 AM
GZR4DR's Avatar
Default Re: bleeding the clutch (Mista Bone)
Use 2 people. Leave the lid off, pump a few times, release the bolt slightly, tighten, pump again, realease the bolt slightly so the fluid sprays out. Repeat until you get a nice spray when losening the bolt. It should not be a dribble or whatever. Like i said, use 2 people, it goes much quicker. Also refill as necessary when pumping because the fluid level will drop.
Use a cup or something to catch the DOT3 fluid so it doesnt get everywhere also.
Old Oct 5, 2002 | 04:17 PM
kuelerz's Avatar
Default Re: bleeding the clutch (GZR4DR)
were do you fill the fluids up, i just finished my swap and i need to refill the tranny and the clutch. i know all about motors but when it comes to trannys i am a dumb@ss
Old Oct 7, 2002 | 02:27 AM
Mista Bone's Avatar
D Tranny Guru
1sthonda
Sep 25, 2010 05:48 PM
starquestchris
Mar 23, 2010 10:25 AM
shortlid
Apr 14, 2007 09:20 AM
Merilious
May 14, 2005 07:09 AM
Qwikrex
Apr 20, 2003 03:27 PM
