B series tranny gurus
Old Oct 4, 2002 | 12:23 PM
johnzm's Avatar
Default B series tranny gurus
what cable trans came i the US? i wnt shor gear ratios, so how can i go about getting the shortest possible gear ratio on a US spec tranny(read easily replaceable parts) i also at the moment have a Y1 w/ LSD. would that move over to the US tranny ?
Old Oct 4, 2002 | 12:35 PM
Fishcat37's Avatar
Default Re: B series tranny gurus (johnzm)
The only B series VTEC cable trans that came in the US was the YS1. This was found in the 92-93 B17A powered GS-R. not sure what you mean by move over to the US tranny....?
[Modified by Fishcat37, 9:39 PM 10/4/2002]
Old Oct 4, 2002 | 01:29 PM
johnzm's Avatar
Default Re: B series tranny gurus (Fishcat37)
i wanna move my LSD i currently have in thsi tranny to a US trans. i want a shorter gear ratio. whats the shortest gear ratio i cang et in a cable trans, and where can i find one? i would also like to be able to rebuild it as soon as i get it. therfore i want to be able to redily get hte parts in the US
Old Oct 4, 2002 | 04:47 PM
Jared's Avatar
Shortest geared US cable trans is the YS1 from the 92-93 GSR, and afaik your LSD should work using the GSR ring gear.
Old Oct 4, 2002 | 08:22 PM
wickedxboi's Avatar
Default Re: B series tranny gurus (Jared)
i have the ys1 and the gearing is very short(from personal experience). im not sure what the specs are though
Old Oct 4, 2002 | 08:23 PM
xtrafastcivic's Avatar
http://ff-squad.com/Bgears.htm
[Modified by XtraFastCRX, 9:28 PM 10/4/2002]
Old Oct 4, 2002 | 11:35 PM
incubus's Avatar
Default Re: B series tranny gurus (wickedxboi)
considering there was only a few b17's produced a usdm ys1 tranny will not be to easy to find, unless it was used on the gs's also.
[Modified by incubus, 3:42 AM 10/5/2002]
Old Oct 5, 2002 | 12:15 AM
Default Re: B series tranny gurus (incubus)
it would be easiest to get a j1/s1 tranny...
RHDintegXsi
Aug 24, 2007 08:59 AM
Lsos
Feb 23, 2006 09:22 AM
PM-Performance
Jun 14, 2004 08:16 PM
9200RPM
Nov 1, 2003 02:08 PM
