Safe to use torch in my engine bay?
Old Oct 4, 2002 | 12:22 PM
ragejed's Avatar
Default Safe to use torch in my engine bay?
http://www.alumaloy.net
I stripped a hole in my tranny, and this stuff come to mind. I saw it many years ago on public access tv. I was thinkin about doing it to fill the hole i stripped, re-drill, and re-tap it. good as new...However. How safe is it to put a propane torch in the engine bay>?
Posted this in Tech..never got a response. Maybe you guys can help me out?
Old Oct 4, 2002 | 12:24 PM
kshymkiw's Avatar
Default Re: Safe to use torch in my engine bay? (ragejed)
i think you might have to drain the fluids and what not, and make sure the car is OFF. I think if you do that it should be safe to do.
Old Oct 4, 2002 | 12:25 PM
Nate B's Avatar
stay away from fuel lines and keep the flame to a minimum and you should be o.k.
:Note: I said "Should" not "Will" I don't want to be liable if you blow yourself and your car up
Old Oct 4, 2002 | 12:32 PM
ragejed's Avatar
Default Re: Safe to use torch in my engine bay? (TypeR#1111)
I was thinkin about puttin in a fuel cutoff, or pulling the fuel fuse, and run the car till it stalls, so there is no fuel , or little fuel near the engine bay..sound good?
Old Oct 4, 2002 | 01:23 PM
JDMITR222's Avatar
JB weld the Biatch!
Old Oct 4, 2002 | 01:42 PM
ragejed's Avatar
Default Re: Safe to use torch in my engine bay? (JDMITR222)
I heard about JB weld. What exactly is it?
Old Oct 4, 2002 | 03:44 PM
Big Phat R's Avatar
I worry about products that have the label "As Seen on TV"
Old Oct 4, 2002 | 04:37 PM
ragejed's Avatar
Default Re: Safe to use torch in my engine bay? (Big Phat R)
Ya, but some of the products work. like that Rotisory gril thing. God, it makes great food!, seriously!.. But ya, Its just a metal aloy. Not some revloutionary chemical that turns cats into fish
Old Oct 4, 2002 | 07:37 PM
Tony the Tiger's Avatar
You should be safe as long as you use a damp cloth to cover up most of the fuel and electrical components inside the engine.
dropkneeyoungin
Oct 10, 2009 07:55 PM
claymore
Honda Fit
Sep 4, 2009 08:01 PM
Drum_Guru
Jan 9, 2004 06:28 PM
Blockhead G
Sep 3, 2002 07:16 AM
