what might be the problem in this accord
Old Sep 16, 2011 | 06:57 AM
hiphop23j's Avatar
Default what might be the problem in this accord
i recently bought an accord 99 lx v4....now the person told me the cat is bad....when i drive in d4 it takes very long to take off but doesnt seem like a slipping feel...when i put it in d2 or d1 it takes off great and gets going like no problem...what might be the problem...i was thinking maybe cat and torque converter but im not sure... help me out guys...thanks
Old Sep 16, 2011 | 08:18 AM
Steve Z's Avatar
Default Re: what might be the problem in this accord
Does not sound like anything to do with the cat converter. Sounds like transmission problem. If you shift it manually it's fine but from D4 it lugs? That sounds like transmission to me. Not starting from 1st gear when in D4. You should be able to tell by the sound. Is it shifting from 1st through to 4th from D4? I would shift it manually from D1-D4 from a standing start until you can find out whats wrong with the transmission in D4.
Old Sep 16, 2011 | 08:58 AM
hiphop23j's Avatar
it shifts in d4 from 1st to 4th its just that is feels like a slug until like 30 mph is if its pulling something heavy....rpms are at 2-3k and struggling to move until it finally pics up speed...but when i put it in d2 picks and takes of fine...
Old Sep 16, 2011 | 01:57 PM
Steve Z's Avatar
D2 from a standing start is actually taking off in 2nd gear. It's the only position that does this and is used in winter when you want to get through snow from a start without spinning the wheels. If you are saying D2 after you are up to 30mph or so then it is probably downshifting and thats why it feels peppier.
Old Sep 17, 2011 | 04:16 PM
hiphop23j's Avatar
i use d2 to try to drive in general untill i get like 30 mph then i put in d4...but when its in d2 from 0 it goes like a slug reving to 3k and moving slowly to get speed
Old Sep 17, 2011 | 04:33 PM
MAD_MIKE's Avatar
MM Gruppe B
'99 Accords still have D3 yes? If you don't plan on driving for long distances above 25MPH, or have alot of stop/go driving put it in D3. Saves on shifting wear. Uses gears 1-3
D2 is for snow or slow non stop traffic ~<25MPH(saves on shifting/wear). Shifts into 2 and stays there.
D1 is if you plan on going up a steep incline, pulling a heavy load at a slow speed <10MPH. Shifts into 1 and stays there.
Old Sep 17, 2011 | 05:38 PM
accordmatt's Avatar
my car did this also it was tranny going bad and bad torque converter.i lasted about 4 yrs actually with this issue oodly.
Old Sep 21, 2011 | 12:04 PM
hiphop23j's Avatar
lol i checked what the check engine code was and it says seloniod so im not sure if its the censors or the tranny about to crap on me
Old Sep 21, 2011 | 01:12 PM
MAD_MIKE's Avatar
MM Gruppe B
What was the code? There are at least four solenoids in the transmission. It also could be the wiring to the solenoid that is damaged/grounded that could be causing the code.
Old Sep 22, 2011 | 04:20 PM
hiphop23j's Avatar
it came up as p0700
Old Sep 25, 2011 | 04:20 AM
hiphop23j's Avatar
Old Sep 25, 2011 | 06:55 AM
Steve Z's Avatar
P0700 is a sub code for the trans side of the computer. The code for the trans is the P0780
Mechanical Problem in Hydraulic Control System for Shift Solenoid Valve A and A/T Clutch Pressure Control Solenoid Valves A and B, or Problem in Hydraulic Control System
Generally speaking, I doubt a soleniod is going to fix this. Alhought it might in a lower mileage car, this is usually indicitive of a problem internally within the transmission which means live with it by manually shifting from 1-4 if that helps or get another AT. Sorry.
hatzipri90accord
Apr 1, 2011 12:10 AM
lasdj
Feb 26, 2010 01:15 PM
96DX
Sep 10, 2003 01:15 PM
