passenger side fuse #10 keeps blowing
Old Sep 15, 2011 | 11:14 PM
tourbo24's Avatar
Default passenger side fuse #10 keeps blowing
I just started getting a weird problem. The passenger side fuse #10 keeps on blowing every time i turn the headlight on. After the fuse blows the tail lights, driving lights, cluster lights all dont work. I was thinking that the problem might be with my aftermarket radio which i installed around 2 months ago. There were a few wires that didnt connect to anything and i cant remember if i put tape at the ends of them to make sure they didnt touch anywhere. If its not the radio, what could be causing the fuse to blow as soon as i turn the headlights on?
BTW, its a 1999 Accord Coupe EX.
Old Sep 16, 2011 | 05:00 AM
CDelgado220's Avatar
Default Re: passenger side fuse #10 keeps blowing
Originally Posted by tourbo24
I. I was thinking that the problem might be with my aftermarket radio which i installed around 2 months ago. There were a few wires that didnt connect to anything and i cant remember if i put tape at the ends of them to make sure they didnt touch anywhere. If its not the radio, what could be causing the fuse to blow as soon as i turn the headlights on?
Check on the wires
Old Sep 17, 2011 | 03:04 PM
tourbo24's Avatar
looks like i solved the problem, when i did the radio there were like 4 wires that didnt connect to anything and i forgot to tape the ends off. turned out that 2 of the wires got stuck together and were causing the fuse to blow. after taping the ends off everything works fine.
S33
Dec 27, 2014 10:22 AM
maparman
Jun 9, 2013 07:09 AM
byc_cb7
Sep 28, 2009 02:45 PM
4g4dcruisin
51
Jul 29, 2009 02:50 PM
jerbear!
Sep 12, 2004 11:53 AM
