Question about factory/aftermarket LSD
ok so i know that the OEM ITR JDM/USDM trannys have LSD and a way to spot them is to look through the axle hole and you should be able to see all the way through without a bar obstructing your view. My question is are all LSD like this? IE. Quaife/Phantom Grip/OBX or do certain aftermarket LSD have a bar inside the axle hole still?
its all good bro might as well learn as much as i can righttt?
well ok since the phantom grip is not a full LSD does that mean it might have a bar there? cuz i saw a picture of how to install it and it looks like its a bolt on not an actual differential o-o
The Phantom Grip will still use the center bar(differential pin)...it wraps around it.
I can say this, a PG does have a use.
When the diff pin wears through, it will keep the spider gears contained and not destroy the case.
The PG doesn't cause the explosion, Honda's weak diff pin does that.
LSegHatchy
Oct 28, 2004 12:20 PM
