B Series 14:1 Custom Header~
Old Sep 15, 2011 | 01:25 PM
D.O.C.-Race's Avatar
Default B Series 14:1 Custom Header~
Working with a friend on a custom header for his 13.8:1 B series all-motor car. Building a Stainless header 2" primarys; merge collector is a 3.5" outlet. We'll be building the exhaust system tomorrow. Header is getting welded this evening then to get some partial throttle tuning until the exhaust is done.
Old Sep 15, 2011 | 10:38 PM
SlaminSohCivic's Avatar
Default Re: B Series 14:1 Custom Header~
bump awesome ready...Question how does he get both of them Throttle bodys to open at same time
Old Sep 16, 2011 | 04:42 AM
Nite_2nr's Avatar
dude, not 100% sure but i think the choke on that header is way to big and prob going to loose power. Big HP K series dont even use a 3 inch choke. Either way though, it is looking very good.
Old Sep 16, 2011 | 05:06 AM
rickbeastwood's Avatar
When you say 3" choke, Do you mean the collector?
A couple of buddies of mine rock the 3" collector and make Nice power and there b and k setups. It must be the way they set the runners.
I like it though!!!
Old Sep 16, 2011 | 05:23 AM
HellaFab's Avatar
I was researching primary/choke and exhaust size yesterdfay before i was sidetracked to the articles on endyn's website.... is 2" primary standard for a 2.0L?
Your header looks great. once welded it should perform well.
nite 2nr... is the choke size coupled with the exhaust size tuned to maximize exhaust gas velocity, or what would make the difference in performance from header to header?
Trick, afaik choke refers to 3" at the merge, then you taper out into your exhaust size. these "tuned" type of exhausts are common on snowmobiles where they change size to tune for best power. I am just trying to confirm the solid reason that it creates more power...
Old Sep 16, 2011 | 05:25 AM
weiRtech's Avatar
OG Fabricator
i'd add a venturi and some anti-reversion chambers. what is his power goal?
Old Sep 16, 2011 | 07:41 AM
Nite_2nr's Avatar
heres a good link to headers from burns stainless, will help with all the terms
http://thespfiles.blogspot.com/2006/...ation-and.html
heres a little section in there too about hondas
Collector Choke (minor diameter) - This is the size the can make or break a good header This doesn’t need to be 3" unless you have something super weird going on with your engine. I have not design a Honda header yet that even needs close to a 3" Collector choke. I’m not saying it wont or cant happen, I’m just very skeptical of it
Old Sep 19, 2011 | 09:24 AM
SlaminSohCivic: The throttle bodies have a coupled linkage so they both open up.
Thanks guys. Did some tuning with the car on Saturday and it's looking really good. The car is getting tuned on E85, I have a dyno video of the car that I will be sure to post up this week when I have a chance.
Coupled the custom DOC Race exhaust system to the header before we hit the dyno; still have to finish up the tips this week before we go to the track this weekend...
Old Sep 19, 2011 | 02:38 PM
ReV LiMiT's Avatar
looks good. its different. lets see how it looks from the back with the dual tips.
Old Sep 19, 2011 | 07:38 PM
ToxicFabrication's Avatar
OG Fabricator
No back purging huh?
Old Sep 20, 2011 | 05:16 AM
JayWest's Avatar
wow, thats a umm....interesting design
please keep us posted on dyno results
if possible post some more pics of the intake setup
Old Sep 20, 2011 | 10:35 AM
Fully penetrated without back purging on this setup. Has worked out just fine for us.
Old Sep 20, 2011 | 10:36 AM
Dual tip's will be up by the end of the week
Old Sep 20, 2011 | 10:51 AM
vtec_lude's Avatar
Although it may be fully penetrated, all the sugaring and brittleness is inside. I hope it doesn't crack, but it may do due to the fact that you don't have a flexi on there.
Definitely an interesting design though so props to you.
Old Sep 20, 2011 | 11:28 AM
likwidchz's Avatar
Dahahaha Holy donkies.
And you guys are local to me, what tuning software is that rocking?
--Aaron
By the way that tig welder might want a watercooled torch for christmas, that torch looks HUGE! I use a weldcraft WP-20? I think...
Old Sep 20, 2011 | 11:37 AM
OG Fabricator
Hmmm, also noticed on one of the pictures of you evo manifolds it wasn't purged. This will lead to issues for the owner later down the road.
Looking good other then that
Old Sep 20, 2011 | 12:23 PM
McRussellPants's Avatar
I was really hoping this was a 14 into 1 header.
this thread is a let down.
Old Sep 20, 2011 | 01:16 PM
likwidchz's Avatar
I can see 4 cylinders, but what about the other 10 where did they come from??
Old Sep 20, 2011 | 02:07 PM
OG Fabricator
Old Sep 20, 2011 | 02:40 PM
OG Fabricator
Also, I can clearly see almost zero penetration on the welded v band flange on the rear section.
Want to make it clear I'm not trying to pick on your work. Just observing what I see more then anything.
Any pics of it off the car?
Old Sep 20, 2011 | 03:48 PM
:ToxicFabrication: No offense taken. I don't have any pictures of the header OFF the car after it was completely welded sorry. With this All-motor setup the way we built this system and welded it has worked out for us numerous manifolds and for years. I appreciate the concern Toxic.
Old Sep 20, 2011 | 03:56 PM
likwidchz's Avatar
Toxic you do some fantastic work!, I dont want to thread jack, but what happens when you dont back purge?
I ask this as I built a 3 inch exhaust for my H22 last month using flanges and all that and didn't back purge anything "I dont have the extra hoses" ... I understand the concept but what exactly happens to the metal when argon isn't on the other side of the steel?
Doc Race --- Its fantastic when your able to jack the car up and start fabrication... I had my civic about a foot off the ground when I made the exhaust and it was annoying as crap due to the fact that its cramped and things are upside down and backwards, you tig something and put it back on and its on the other side of your line and the wrong direction! things like that make me crack up and also frustrated at the same time. My exhaust setup I made with my tig I bought last year... Totally an awesome project, way fun and makes me wish I made all the exhaust setups.. The whole thread for ***** and giggles.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/h22a-www-logicmotorsports-com-tri-y-highend-header-2965175/
--Aaron
Although I don't foresee back-pressure ever being an issue with that setup!
Old Sep 21, 2011 | 09:12 AM
Dyno on Friday i'll be sure to update for some numbers
Old Sep 21, 2011 | 09:57 AM
rich7777's Avatar
Very nice !
Old Sep 21, 2011 | 10:27 AM
likwidchz's Avatar
Hahah that looks so nuts...
