94 del sol limp mode bad ecu?
Hey guys I have a 94 sol si. Recently I got a CEL and the car started running crappy, idling around 1400 and limiting around 4k. From reading around I heard this means my CPU is in limp mode. Did the jumper trick with the service connector and the CEL is staying solid with the car turned to ON but the SRS blinks a code. So, should I buy a new ecu or could it be something else?
cmwalker
May 21, 2013 04:49 PM
