Diamond racing wheel set up?!
Old Sep 15, 2011 | 10:40 AM
ezcape's Avatar
Default Diamond racing wheel set up?!
Hey, I'm trying to order some diamond racing wheels from diamondracingwheels.com. Which i'm just getting confused with the backspacing, clearing my caliper, etc. wanted to see if anyone on here has the same set up i would need or know the specs of the wheel I should be getting. Also the tire size I would need to run on them. I have a 97 Civic hatcback. With ground control coilovers with buddy club camber kits. Thank you all for the help in advance.
Old Sep 15, 2011 | 10:46 AM
alphalanos's Avatar
Default Re: Diamond racing wheel set up?!
I do know that to run those you will probably need to do a good bit of fender work and stretch tires, and run a good amount of camber. You probably wont get much help here with tires because they dont allow threads about stretching. Personally I would advise against it because it is not safe and does nothing for performance. But its your call
I want to say that the wheels are 15x8 +12 offset with around 5" of backspace, or something like that. Give them a call to see what they offer.
Old Sep 15, 2011 | 10:57 AM
ezcape's Avatar
That is true, I'm not trying to go crazy camber/6 point turn status. I see they offer 15x6. 15x7. Would that be a safer set up?
Old Sep 15, 2011 | 12:38 PM
toyomatt84's Avatar
Sanji
Actually, they offer an array of widths. But, sadly, only a select range of offsets due to a limited design of faces (all have the same profile, just different bolt patterns).
To be honest, the widest you could get away with (when running properly sized tires) would be their 15x7 with the highest backspacing they have available (4.5" backspacing for the Stock Car Series wheel). Make sure to request the safety bead in the barrel, or you're probably going to bend the wheel on the first drive you take with it. Also, you'll need a spacer to clear the front brakes of your car.
Danny Roa
Honda Civic (2001 - 2005)
11
Mar 12, 2014 07:23 AM
Low and no vtec
Aug 29, 2013 07:12 PM
jkn1515
Honda S2000
19
May 27, 2007 06:19 AM
kloscivicsi
Honda S2000
Apr 3, 2007 06:20 PM
eg-r
Nov 3, 2002 01:46 AM
