98 Civic - surging idle and CEL codes 7, 14, 41, and 65
hi, i just bought a 98 civic 4door 1.6l automatic,
the idle is going up and goes down , that make the transmission impossible to shift normally, its skipping when iy shift,
but when i unplug the tps sensor, its iddle high but stay at the same idle, so i can drive it whitout make the tranny skip.
so i CHANGED THE THROTTLE BODY completly today and its does the very same problem, so i get out the error code, i did get
- 7 TPS - throttle position sensor
- 14 IAC (EACV) - idle air control valve
- 41 Primary oxygen sensor heater
- 65 Secondary oxygen sensor heater wire (black wires)
can someone help me there, im confuse
Problem fixed?
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
