Battery won't stay charged , alternator is good also. 00' civic si
Old Sep 14, 2011 | 05:04 AM
Jdmbryan's Avatar
Default Battery won't stay charged , alternator is good also. 00' civic si
Ima try and make it as clear as I can the car is a 2000 Honda civic Si , basically stock, I got the battery checked and it was bad so I put a new one in and it turned right now it drove good and started good for about two hours, before that I had took the alternator off just to make sure it wasn't bad and I went to autozone got it checked and it was good, so I put it back on yes the belt is tight, and I then replaced the battery and it worked fine for the rest of the night, now it won't stay on without me revving up the motor, if it's at idle it will be fine but as soon as I press the brake pedal it'll turn off same goes if I try turning on corner lights or anything. So what I need to know is what can I check next? Grounds? Fuses? Any in specific? Any help will be appreciated.It also threw about 7 codes which are the following; p1298- Electric Load Dectector (ELD)Circut High Input. P0135-heater condition (heated oxygen sensor bank sensor 1&2) P0500-VSS circuit malfunction . P0300-random cylinder misfire. P0304-cylinder number 4 misfire detected.
Old Sep 14, 2011 | 05:06 AM
Former User's Avatar
Default Re: Battery won't stay charged , alternator is good also. 00' civic si
Is 7.5A dash fuse 15 blown?
Old Sep 14, 2011 | 05:11 AM
Gi'Joe Rosario's Avatar
Bro that happen to my prelude i went thru like 3 batteries, my problem was a wire shortage so check all of ur wires
Old Sep 14, 2011 | 07:11 AM
Anderson413's Avatar
My inital thought was the fuse also as Ron stated. If it's blown, it will not charge as the circuit is open.
Old Sep 14, 2011 | 08:31 AM
ChristianL's Avatar
Do you have a volt meter (or can you borrow one)? If so, get the reading off the alternator while the engine's running. I know it just got checked, but it'll give us more info to go with.
Since it seems to get better when you rev the motor, I'd say it's not the battery. However, I'd agree with Gi'Joe that it's probably a wiring issue. Try checking connections at the alternator, and clean the grounds.
Also, check cables going to the battery leads. I've had loose ones before that seemed to go on tight, only to find I could slip them off with a little wiggling.
Are you running any extra stereo equipment or other electrical goodies?
Old Sep 14, 2011 | 08:52 AM
thatboyrob's Avatar
Happened to me a couple weeks ago, replaced the battery, took the alternator out and got it tested, but it still kept draining my battery. Ended up being my battery cable from the positive terminal was worn and no good.
Old Sep 14, 2011 | 07:11 PM
Jdmbryan's Avatar
So it was Somethen to do with my wiring somewhere in between the alternator and battery it had a short, got that fixed , now I need new terminals, haven't looked around or googled but anyone want to tell me how to change them?
BiggieDaBandit
Nov 2, 2014 10:56 AM
tish_86
Classic Hondas
Jun 3, 2014 08:00 AM
hialeahzbg
108
Jun 13, 2011 01:45 PM
samvilay
51
Jan 15, 2008 08:27 AM
levison
Jan 5, 2008 12:11 PM
