need some one to make me this..
Old Sep 14, 2011 | 01:12 AM
cibao2ner's Avatar
Default need some one to make me this..
i need an adjustable testpipe like this one...but it has to be 3 inch...2 bolt on one side and 3 bolt on the other...need to bolt on my bisimoto header to my thermal 3 inch exhaust...i can provide aproximate lengh...but i need to be able to clock it and shorten it or make it longer.....i have a long piece of mild steel 3 inch pipe so if someone wants to just make me both open ends so i can just slide the pipe....either will work
Old Sep 14, 2011 | 12:07 PM
SovXietday's Avatar
Default Re: need some one to make me this..
Just an FYI, my experience with those is that they pretty much all leak. Why do you need to change the length?
Old Sep 14, 2011 | 02:37 PM
TIG WERKS's Avatar
you probably just use single slip joints.....I havent had issues (knock on wood) with double slip joint assemblies.
Dc2_ShowStopper
Honda CR-V & Element
15
Apr 9, 2013 02:53 PM
dragdatzu
Apr 10, 2008 08:24 PM
aznryd3r
Apr 26, 2006 09:04 AM
Hypertek99
May 18, 2005 07:15 PM
