1995 SI prelude oil pan
Old Sep 13, 2011 | 05:23 PM
prelude tinker's Avatar
Default 1995 SI prelude oil pan
take front driver tire off jack up and jack stand the drivers side. Take center support off three in front three in back. Unbolt exhaust bolts 14 mm bolts connected to the motor three of them also exhaust support two 12mm bolts. The oil pan should be clear of all engine parts. Take all 10mm bolts off around pan and dust shield /heat shield pry off gently with mallet comes loose easily. If its tricky and gets cought up wiggle it out patients from drivers side or under neath dont bend any thing.oil pan to gasket put black rtv oil resistant run some on oil pan and gasket so you can get a good seal on the side that sticks to the block run rtv around the corners and by the curve that attaches to motor put everything back pan bolt are 8 to 12 ft pds dont over tighten cool you did it i hope this info was useful
Old Sep 14, 2011 | 04:47 PM
horsepowerless's Avatar
Default Re: 1995 SI prelude oil pan
If you're doing a DIY, pics would help. I know what you're saying, but kids who usually need these DIY's need pics too.
lazyxmofo
Mar 9, 2011 06:26 PM
bopbop93030
Jul 4, 2009 06:40 AM
stets
10
Mar 2, 2008 04:12 PM
O16581724 5 2 5
13
Aug 2, 2005 04:49 PM
hondaracing1
11
Mar 18, 2004 04:01 PM
