98 Civic EX coupe power window problems
Old Sep 13, 2011 | 10:14 AM
DelSolDon's Avatar
Default 98 Civic EX coupe power window problems
The power windows in my 1998 civic EX coupe have worked fine until just the other day, the passenger side window will not go up or down from the driver's side switch. It will go up (or try to go up since it is already closed) from the passenger side switch, but will not go down. Yes, i have checked the window lock switch on the driver's side unit.
I have not yet run through the helms tests, but just seeing if anybody has had a similar problem before i get around to fixing it myself.
thanks
Old Sep 13, 2011 | 10:28 AM
TOO MUCH TORQUE's Avatar
Default Re: 98 Civic EX coupe power window problems
the master switch needs to be replaced.
Old Sep 14, 2011 | 09:39 PM
92EGLSVTECEATER's Avatar
If the window will go up on the passengers side but not the main switch than i believe that either the master switch is faulty or isnot getting a proper ground at the switch.Find a schematic,removed the switch with it still hooked up.When operating the switch probe the appropriate wire terminals with a dmm and recorded your results.The window motors have 2 wires running to them that change polarity when pressed down and or the opposite direction.Just make sure you check your grounds.Good luck Peace
Old Sep 14, 2011 | 09:41 PM
Damn i Forgot,FYI the passenger switch is feed from the master switch.That is all Peace
Old Sep 17, 2011 | 02:44 PM
DelSolDon's Avatar
switches tested out OK, seems to be a short/break in either the BLU/YEL or BLU/ORN wires leading from the master switch to the passenger's switch. will test them tomorrow for continuity from one switch to the other.
Old Apr 30, 2017 | 03:52 PM
Lorilee's Avatar
Icon5 Re: 98 Civic EX coupe power window problems
I also have a 98 Honda Ex with window issues. It started with passenger window only working from passenger switch. Then the drivers side quit but started working again a few weeks later but when it did the passenger side quit all together. I had the motor replaced on passenger side. It had been making a clicking sound while car was on so the guy figured that would be it. No go still. Before I replace main switch is there a way to find out for sure with out a shop? Thanks
brent_si
Honda Civic (2006 - 2015)
Sep 18, 2014 09:11 AM
TUR3Ovtec
11
Aug 2, 2009 10:41 AM
guamie
Oct 12, 2007 10:51 AM
D16Z6_turbo
Aug 4, 2005 09:21 PM
