Exedy twin disc HELP!!
Old Sep 13, 2011 | 05:21 AM
Laojoeturbo's Avatar
Default Exedy twin disc HELP!!
Ok I got a used exedy twin disc for my lsvtec hydro trans. about to put it on. On the two disc tHey are identical there is one side that's flat and the other with a hump on it. I have no idea if the flat side of the Clutch disc should be facing the flywheel side or pressure plate side. Please give me input i already dropped the tranny just need to find out asap. I want to get it done tonight. Thanks
Old Sep 13, 2011 | 11:32 AM
95 integra's Avatar
Default Re: Exedy twin disc HELP!!
#1 http://www.exedyusa.com/multimedia/s...twin_notes.pdf
#2 http://www.exedyusa.com/multimedia/s...rd%20Multi.pdf
It really only fits one way and I believe that is the first plate goes with the longer part of the splines facing toward the flywheel and the second toward the pressure plate.
Old Sep 13, 2011 | 02:58 PM
Thanks brotha. I got everything sorted out. I called exedy.
boosted350z
Nov 27, 2004 06:49 AM
tcollins
Nov 10, 2004 11:39 AM
tallblondkid
Aug 19, 2004 10:03 AM
raene
May 28, 2004 07:34 AM
