B18 Swap Questions
Old Sep 12, 2011 | 09:37 PM
GODofWARREN's Avatar
Default B18 Swap Questions
Alright so here is where Im at, I have a 1993 Civic EG coupe ( EX ) and Im dropping a B18 LS ( 1992-1995 ) in it. I have a B16a2 wiring harness, a P2T Civic Si ECU, and a obd2 MSD wired Distributor. How can I make that setup work on the B18 ( a obd1 Head )? really the only thing that is confussing me is the Distributor, because it has 2 connectors from it and the harness only has 1 for the distributor,and Ive heard cutting and splicing wires may be an easy fix..? Looking for Fast help and advice , thanks
Old Sep 12, 2011 | 09:49 PM
tehtyler's Avatar
Default Re: B18 Swap Questions
easy use a odb2 intake and it should all clip up and is your dizzy for a ls head or for a vtec head
Old Sep 12, 2011 | 09:57 PM
So I just use the obd2 intake manifold and it would make the obd1 Distributor hook up right..? And Non vtec I believe. its a obd2 LS Dizzy
Old May 12, 2013 | 12:10 PM
Austin.em1's Avatar
Not trying to hijack, but I have a b18b2. (Obd2) but I'm running the stock b16 vtec wiring and I finally got the p75 it needs to run right, but it won't hook up. Help!
Old May 12, 2013 | 12:50 PM
B_Swapped93's Avatar
Why do you have a Si harness for a ex(y8) and are trying to drop a non vtec b18 into it seems like you're off a bit. why didn't you just get an ls harness
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
delorean
Mar 28, 2011 01:51 PM
Built4Battle
Jan 23, 2011 09:46 AM
nikkarocky
Apr 10, 2007 12:54 PM
delux247
Apr 4, 2003 05:57 PM
