coolant coming from bottom of head
As the title states, i have coolant coming from parts of the bottom of the head where it meets the block. The block is a f22a6 the head is a f22b2. The b2 snapped a crankshaft in half. Got a new block, had it machined and built at a machine shop. The same shop checked out the head to be fine. The head gasket is for a b2. Someone please help me figure out my problem. Everything was torqued to spec and in sequence. All help is appreciated.
Pressure test your cooling system to make sure it's coming from the gasket and not something stupid like one of the small hoses coming off of the waterpipe on the back of the block.
Gonna take the head to a different machine shop Friday and get a headgasket from honda. Hopefully all works out well. This car has been out of commission for far tooo long.
And make sure the head bolts where torqued in the right sequence, a little at a time. Torque all to 20 lbs, then up it a lil bit and redo each one in the right order and keep doing that till they are at spec.
ITR_1211
Jan 5, 2004 09:04 PM
