****OUT THE GAME****SALE****DX SHELL***FULL-RACE***EDELBROCK***ITR/CTR PARTS***
Old Sep 12, 2011 | 05:53 PM
magcrf's Avatar
Default ****OUT THE GAME****SALE****DX SHELL***FULL-RACE***EDELBROCK***ITR/CTR PARTS***
So I bought a Subaru and Im getting out of the Honda Game.
1993 Honda Civic DX SHELL. -PROJECT CAR-
COMES WITH:
GSR interior:
Front and rear seats, Door panels and Dashboard.
Brake line tuck:
ALL Brakes lines have been tucked into the cab with stainless lines. Prop valve has been mounted where SRS box used to go.
Full Wire tuck:
All wires to lights and rad and motor have been tucked. Motor harness is set to connect all connections through the heater hole. Fuse box is tucked under passenger side of the dash.
SUSPENSION:
Skunkworks (Skunk2) coilovers on white adjustable tokico shocks.
Skunk2 Pro upper control arms with adjustable chamber kit.
Brand new wheel bearings and brand new ARP extended Wheel studs on the front.
Brand new Rotors and brakes on the front.
Rear drums are stock. Works fine and ebrake works fine.
MOTOR MOUNTS:
comes with B series Motor mounts 3m Window Weld and inserts on mounts.
MISC:
Comes with Carbon Fiber Rear Spoiler and Carbon Fiber Hood.
Comes with sidemarkers and orange corners with fog lights.
Car was deep in the 12s on 205 Drag radials and 300HP.
Tags expired 2009.
$1600 OBO
FULL-RACE ProAM Traction Bars
EG/EK/DC with B series.
Brand NEW in BOX Never OPENED
"Full-Race now offers a new and improved traction bar system for high power street, race, and road race cars. This ProAm style traction bar system utilizes a revolutionary design incorporating an additional motor mount. This motor mount prevents unwanted motor and transmission movement that is commonly seen on a high output vehicle.
Engine vibrations will be increased somewhat with this type of motor mount. However, this mount can be easily removed in a few minutes with a basic set of hand tools. Simply install the mount when need be and remove it when it is not desired."
$250
CTR Crank Pulley
used for maybe 100 miles if that.
$50
GSR JG Edelbrock Victor X Intake Manifold
Race Intake Manifold
These are AWESOME!!!
Light Weight Cast Aluminum
7.5 LBS lighter than the stock Honda Acura Intake Manifold
Super High Flow, Large Runner & Plenum Performance Intake Manifold
MAKES BIG POWER!!!
Especially with Performance Cams & Big Bore Throttle Body
Optimized for 7000-10000 RPM range
Pre-bored to accept Large Throttle Bodies
AWESOME FOR TURBO OR SUPERCHARGERS!!!
FITS GSR HEAD.
$200
Weld on 4 point RollCage FOR EG
Comes with pre-bent ROLLBAR and the links to make it a 4 point.
Professional installation required.
$250
Sparco Racing Seat with Harness
Black seat, I never got a chance to use it.
$200
ITR Shift Linkage
Gold Shift linkage from ITR, Much lighter and tougher then regular shift linkage.
ES bushings on the back dont know where the front went.
Short dual bend shifter installed.
$80
Old Sep 14, 2011 | 07:14 PM
magcrf's Avatar
Default Re: ****OUT THE GAME****SALE****DX SHELL***FULL-RACE***EDELBROCK***ITR/CTR PARTS***
ttt
angryhillbilly
Dec 21, 2012 06:07 AM
magcrf
Oct 24, 2011 07:50 AM
HickamHatch
Oct 11, 2009 09:38 AM
ctreg6
Jul 21, 2008 06:36 PM
KEEP-IT-CLEAN
May 16, 2008 08:14 AM
