coolant hose issue
ok so i have a 2000 civic si and the thermostat housing im using has been welded up theres only one big brass nipple coming out of it where where should it be running to also the brass nipple the big one on the intake manifold where should that be running ?
ok scratch that i was wrong what i have is a water neck thermo housing whatever you wanna call it has no brass fittings at all so i have the brass fitting on the gsr head and the one on the intake manifold now the way have it ran is the fitting on the head is running to the heater control valve and the one on the intake to the other side of the heater core ??
could you give us some more info ? what motor are you running ? the b16a2 or a b18c1 ? a pic of what your looking for ? if you look on some of the online dealerships they have exploded views of the hose's like majestic honda
yea i looked its a b18c5 but the thermostat housing was all welded up every hole except the radiator hose the hose on the intake manifold that im talkin about is looped from there to the tstat housing but i dont have that fitting
SwappedTURBOegg
Aug 28, 2013 06:44 AM
Nikoli
Oct 26, 2004 02:40 PM
