Old ek won't start
Old Sep 12, 2011 | 09:37 AM
Kure1121's Avatar
Default Old ek won't start
So I just purchased the vehicle from a dude in Texas I was driving it to Arkansas and everything was working perfectly until we stopped to get gas and it did not want to start anymore... We towed it home but still can't figure out what's wrong, any help?
Old Sep 12, 2011 | 10:15 AM
Kure1121's Avatar
Default Re: Floss old ek!
Im not so good with cars but it turns over Theres spark seems like ts not getting any gas we checked all spark plugs and wires all the fuses everything is fine IM not sure what else for details we checked the starter at autoparta store and its working as well
Old Sep 12, 2011 | 10:17 AM
Kure1121's Avatar
Yeah I just wanted to see if there was anythingwe could do before taking it to a shop
Old Sep 12, 2011 | 10:42 AM
Former User's Avatar
Default Re: Old ek won't start
Is spark bright white at all 4 spark plugs?
Does the fuel pump prime when the key is turned from off to ON(II)?
Does the CEL remain on steady when the key is turned from off to ON(II) or does it turn off after 2 seconds?
In the future, please create informative thread titles that reflect your tech question. Title edited.
Old Sep 12, 2011 | 11:14 AM
Kure1121's Avatar
Yeah it primes and sparks birghtzzz but the cel turns off after 2 seconds
Old Sep 12, 2011 | 11:18 AM
Kure1121's Avatar
And thanks for helping a noob!
Old Sep 12, 2011 | 11:39 AM
Will the engine start with starting fluid? If not, check the mechanical timing of the timing belt and then compression test the cylinders.
Old Sep 12, 2011 | 01:46 PM
Kure1121's Avatar
Okay are these all things that might have changed over a 6 hour drive?
Old Sep 12, 2011 | 03:43 PM
hyperblu's Avatar
If your tbelt slipped...
Old Sep 12, 2011 | 09:19 PM
Kure1121's Avatar
checked timing belt its good... what we found though is that no fuel was coming through to the fuel rail... the fuel relay was good so we decided to replace the fuel pump... and still no start, and also no fuel coming through we also tried without the fuel filter so the filter isnt clogged...
Old Sep 12, 2011 | 10:03 PM
Old Sep 13, 2011 | 09:56 AM
Kure1121's Avatar
So after checking the fuel pump, we realized the pump itself isnt getting any electricity... but the fuses and relays are perfect
Old Sep 13, 2011 | 09:57 AM
This is confusing as you said the fuel pump primes:
Yeah it primes
Old Sep 13, 2011 | 10:24 AM
Kure1121's Avatar
Yeah sorry about that someone came by and told me it wasnt receiving any electricity
Old Sep 13, 2011 | 04:28 PM
Kure1121's Avatar
And the starter fluid was a fail
Old Sep 13, 2011 | 07:07 PM
hyperblu's Avatar
Just turn your key to ON (II) and listen for a buzzing under the back seat
Old Sep 13, 2011 | 07:55 PM
Kure1121's Avatar
Sorry man im barely getting into the car scene hah but I had someone rewire everything and its working perfectly now! Thanks for the time and help people!
Rage232
16
Feb 13, 2012 10:12 AM
chuckieD
May 18, 2010 12:19 PM
spacin
Dec 27, 2007 11:21 AM
0618turbocivic
Jul 9, 2006 08:31 AM
Honda Sport
Jun 4, 2003 05:27 PM
