Accord AC Compressor kicks in and out
Old Sep 12, 2011 | 04:40 AM
adam_n_tg's Avatar
Default Accord AC Compressor kicks in and out
Hey everyone, I know this is for 1990 and newer but my 1987 is close enough. I have a 87 Accord that the AC compressor kicks in and out like every couple of seconds. No its not the usual cycle of on until it cools down and off. The pressures are good and everything else is good. I can watch the compressor kick on and off every second or so but the ac fan on the front stays on. I have heard something about a temp sensor in the car that can start failing.
Any help??????
Old Sep 12, 2011 | 03:15 PM
Lost Again's Avatar
Default Re: Accord AC Compressor kicks in and out
Thermostatic switch, is that what you are talking about? To test, jump the ac pressure switch wires, check pressures...what happens and what are the pressures if the system stays running......only do this for ~30 sec or so as if the system is low damage can be done,,,,this does sound like low freon. I say freon unless this car has been converted to "something".
Old Sep 12, 2011 | 09:58 PM
chikin pickle's Avatar
You're low on refrigerant.
Old Sep 12, 2011 | 10:01 PM
slomofo's Avatar
GDD Member
Low freon and if the pressures are reading good then you probably have air in there along with refrigerant. It could also be a bad compressor clutch, clogged receiver drier, and many other things, but I would evacuate the system and recharge first because that's the most common culprit.
redbug2
Jul 3, 2014 01:14 PM
billybobdad
Mar 2, 2013 01:33 AM
bradybunch2101
Oct 22, 2012 04:38 AM
Civic Racer X 7
Aug 8, 2007 05:15 PM
