cb7 front rotor question
Old Sep 11, 2011 | 11:20 PM
bdmlilburn's Avatar
Default cb7 front rotor question
90 accord ex 4 door 5spd
just got done installing new: inner tie rod boots, outer tie rods, lower ball joints and a roh conversion.
plan on reusing the old pads since they are still good. my question is about the rotors that fit on the front.
i have a set of rotors for the rear disc conversion. will these rotors fit? is so or if not also when i go to the parts store what car do i need to have them type in to get the correct rotors.
thanks in advance for saving me a headache
Old Sep 12, 2011 | 01:03 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: cb7 front rotor question
...and a roh conversion...my question is about the rotors that fit on the front...what car do i need to have them type in to get the correct rotors.
I'm a little confused, you did the ROH conversion but don't know what car the rotors are for?
Originally Posted by JDM_DC4_Fanatic
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
1998 Acura 2.3CL Front Rotors OEM Part # - 45251-S84-A01
1990-1998 Accord Front wheel bearing OEM Part # - 44200-SM1-008
1990-1998 Accord Front brake pads OEM Part # - 45022-SY8-A01
Originally Posted by CB7 Tuner
98-99 Acura 2.3CL front hub assemblies
90-93 Accord wheel bearing assemblies
98-02 Accord or 98-99 Acura 2.3CL front rotors
90-93 Accord pads (for Akebono or Nissin front calipers)
retain stock caliper
Accord FAQ at the top of the forum is your friend.
Rear rotors are solid, you wouldn't want to use them on the front. They would overheat and the thickness difference would have the caliper piston extended past its normal travel.
S3_EN
Suspension & Brakes
Jul 17, 2017 03:09 PM
johhnytsunammi
Jul 16, 2017 10:26 AM
angrysmileyface
Oct 14, 2016 12:49 PM
fwd0wns
Aug 3, 2012 08:29 AM
nfiniti
May 11, 2010 07:51 AM
